help!! Quick!!
Old Feb 17, 2009 | 01:00 AM
scraper neon's Avatar
scraper neon
Default help!! Quick!!
i need help, i waqs driving home when i came upon a huge puddle went through it and my air intake sucked up a bunch of water, now its making a loud knocking noise
Old Feb 17, 2009 | 01:01 AM
streetracer88's Avatar
streetracer88
take your air box out and dry everything out and put it back in see if it stopped after that including drying the filter
Old Feb 17, 2009 | 01:04 AM
scraper neon
i have an afermarket air intake on it and it makes the noise even with anything hooked up 2 the throttle body
Old Feb 17, 2009 | 01:11 AM
streetracer88
try to dry out your throttle body see if that helps you any you prolly have water sitting in your throttle body
Old Feb 17, 2009 | 01:17 AM
scraper neon
well my friend said to take out my spark plugs and crank it and see if water comesw out the spark plug holes, but do u think the water is whats making the knocking noise?
Old Feb 17, 2009 | 01:19 AM
streetracer88
yes because its mixing with your oil and oil and water dont mix if i was you i would drain all the oil and put fresh in because most of the water you sucked up through your intake will come out in your oil
Old Feb 17, 2009 | 01:29 AM
scraper neon
alright well im gonna go get some oil in a couple mins, so how does oil in the water make the noise?
Old Feb 17, 2009 | 01:34 AM
streetracer88
i think its because the oil is suppose to be a lubricant and when you sucked up the water and it mixed with the oil it breaks the lubricant up making it real thin there for you will hear a noise until you fix the problem
Old Feb 17, 2009 | 02:03 AM
scraper neon
alright well i drained the oil and it only looks a lil milky
Old Feb 17, 2009 | 02:07 AM
I_Ride_Neon's Avatar
I_Ride_Neon
If you let water sit inside the motor, it will rust up your internals.
