will this fit ?
Old Mar 4, 2009 | 08:10 PM
streetracer88's Avatar
streetracer88
Default will this fit ?
will a mitsubishi eclipse engine fit in a neon?without modifications?
Old Mar 4, 2009 | 09:44 PM
chenzo's Avatar
chenzo
https://dodgeforum.com/forum/1st-gen...y-one-now.html
https://dodgeforum.com/forum/1st-gen...dohc-neon.html
http://forums.neons.org/viewtopic.php?f=51&t=331438
http://forums.neons.org/viewtopic.ph...+fit+in+a+neon
theres good info in all of those posts, anything (almost) can fit, just depends on how much fab work you are comfortable/able to do.
Old Mar 4, 2009 | 10:19 PM
streetracer88
thanks for the info chenzo
Old Mar 4, 2009 | 11:06 PM
I_Ride_Neon's Avatar
I_Ride_Neon
The 420a engine is the same block, pistons, crank, oil pump, water pump, bed plate... Thats it. Heads are different. I used a 98 dohc dodge neon lower end in a 95 eclipse.
Old Mar 5, 2009 | 12:29 AM
spudsterier's Avatar
spudsterier
the only engine that will fit without much modding are the sohc and dohc neon engine
Old Mar 5, 2009 | 12:55 PM
GLXRustang's Avatar
GLXRustang
The 4G63 is all mitsu while the 420a is all dodge. 420a's come in the NA ecclipses while the boosted motors get the 4G63. The 420a variant has never been factory turbocharged. If you want the mitsu motor, better buy an eagle talon TSI or turbo ecclipse
Old Mar 6, 2009 | 12:05 AM
streetracer88
my friend told me it would be a sick sleeper if i put a gsx engine and tranny in it so thats why i was wondering thanks for everyones help
