yes but you will need to change the computer and i believe the dash...brain fart but speed/odometer thing lol...(sound like such a tard) and as far as trans idk if the bell housings need to be changed or not
the guy here in nc that has the motor for sale said his computer program matched it up and that it would be a direct bolt in thatnk you though will the dohc 2.0 topend go on this motor im trying to build aq budget turbo neon
yes a DOHC top end will fit...and it will be a direct fit but im saying you will need the 01 computer but if you make it a DOHC..im not sure what computer you would need
honestly your best bet is srt-4 swap...takes more work...its a 2.4 so you need the mounting adapter which is no biggy..modern has it...as far as an all motor..idk check around with the 2gn guys or maybe someone else can chime in..not to sure about the 2gn motors
