so after a little research once i found out my tubo manifold was from a 420a eclipse i come to find it is the same as a DOHC neon does anyone know if the intakes are the same also? if so im doin the obx 420a intake
I really don't know if they are the same, but isn't the eclipse engine the reverse of the Neon? Isn't the exhaust and intakes reversed putting the intake manifold on an eclipse on the firewall side of the car?
i dont care if they are backwards i know mitsu engines well. i want a side mounted tb and can get a eclipse mani cheap i want to know if the flange is the same the exhaust flanges are the same between the two
