Cheap parts!
Old 02-01-2010, 12:17 PM
ohioguru's Avatar
ohioguru
ohioguru is offline
Default Cheap parts!
i bought a short shift from ebay for 7.50....installed it in less than a hour mounted factory **** and have no problems check it out
Old 02-01-2010, 01:27 PM
das2123's Avatar
das2123
das2123 is offline
Check what out?
You got a shorter shifter, not a short throw shifter.
Old 02-01-2010, 05:35 PM
1fast2liter's Avatar
1fast2liter
1fast2liter is offline
maddog sst he makes the best if he is still into it.. he can get up to 70% shorter throws and warrenties his shifters..
Old 02-03-2010, 10:37 AM
ohioguru's Avatar
ohioguru
ohioguru is offline
i didnt post a link but i like the change.....sure its only a 40% throw reduction but for 7.50 i think its sweet and like the feel over factory....just search short shift on ebay motors
Old 02-03-2010, 10:44 AM
das2123's Avatar
das2123
das2123 is offline
I don't believe it shortens the throw, just makes it shorter.
Old 02-03-2010, 12:35 PM
thecause17's Avatar
thecause17
thecause17 is offline
Just shortening the length of the shifter should still shorten the throw of it some as long as the pivot point stays the same.
Old 02-03-2010, 12:44 PM
das2123's Avatar
das2123
das2123 is offline
I guess that's why some people just cut the stock shifter.
Old 02-03-2010, 12:48 PM
thecause17's Avatar
thecause17
Yeah, personally I'd rather not have the shifter be a little nub sticking out of the console. I'd feel like you had to reach so much further that it would be uncomfortable.
Old 02-03-2010, 04:53 PM
1fast2liter
shortening the shifter does nothing to shorten the trhow.. below the pivot the shifter moves the same and throws the same... ever look at rally cars... long shifters with very short throws.... you need to midify the shifter its self and the throw under the pivot... for what you did you could have done a die grinder or sawzaw and cut it for free
Old 02-04-2010, 03:22 AM
thecause17's Avatar
thecause17
The throw stays the same under the pivot, but the distance above the pivot that the **** travels shortens because of the shorter length of the shaft. Simple geometry.
Quick Reply: Cheap parts!
