Sohc crane 12 1/4 mile times?
Old 09-10-2012, 01:20 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
Originally Posted by Trialmaster
Ok, I got it.
I have a Garmin Ecoroute HD i order. Its a obs2 readout with bluetouth. It read all the sensors in to my android phone. It will show the ignition timing online too.
And I am able to store it, so I van look at it on my computer.
That will let you view it. But you need to be able to adjust it. Without adjusting the timing you wont be able to get rid of any ping, and you wont be able to advance the timing for more power.
  #22
Old 09-10-2012, 04:05 PM
Trialmaster's Avatar
Trialmaster
Trialmaster is offline
http://www.cranecams.com/392-395.pdf
What about this one, with aduseble timing?
  #23
Old 09-10-2012, 04:07 PM
Trialmaster
What is "Ping"?
  #24
Old 09-10-2012, 06:41 PM
I_Ride_Neon
What is "Ping"?
http://alternativefuels.about.com/od...detonation.htm
I explain it like this: The heat from lack of fuel, or from to much timing will cause the mixture to ignite before the piston is TDC. This is what "blows" up turbo cars. But this is something that people over look on N/A cars. While the rod is pushing up, the detonation or ping is pushing the piston down. People refer to knock, or ping as a light detonation. Most of the time you cant just "listen" for it, you need datalog it.
And I cannot check the link you sent because it requires a download.
  #25
Old 09-11-2012, 03:19 AM
Trialmaster
I ment this Ignition controler with timing.
  #26
Old 09-11-2012, 03:20 AM
Trialmaster
This is the drag race verson with 2 stage rew limiter
  #27
Old 09-11-2012, 01:12 PM
I_Ride_Neon
I used a similar device made by MSD that retards timing under boost. I have never seen or used the crane one. As long as you can advance and retard the timing then iy should work great. But why not just use the piggyback AEM. Does the same thing, but also controls fuel. The aem is also a lot more adjustable then most.
  #28
Old 09-11-2012, 03:42 PM
Trialmaster
Ok, I go for the AEM, then.
I have no idea how to wire it, but I have a frend that are building a supra turbo, so I will ask for some helpe.
Is there a optimale timing point for the Neons, our do I have to dyno it to tune it?
  #29
Old 09-11-2012, 06:05 PM
I_Ride_Neon
The aem wires in between the factory ecu, and the harness. It intercepts the signals before and after the computer. This allows you to run on the factory ECU tune, and you can tweek it from there. I have never wired or tuned one. I usually always go full stand alone. But if I were to build another 1st gen the aem fic would be my choice.
  #30
Old 09-12-2012, 02:09 AM
Trialmaster
Ok, Thanks
Quick Reply: Sohc crane 12 1/4 mile times?
