Gauge Cluster Swap
Old 12-30-2005, 12:59 AM
highline95jl's Avatar
highline95jl
highline95jl is offline
Default Gauge Cluster Swap
Ok gang I have a basic gauge cluster with just the speeo, gas gauge, and engine temp. Is it possible to do a swap out of onther Neon for a gauge cluster that has a tach. I cant belive I have a manual and no Tach so is it possible to do a change?
Old 12-30-2005, 01:43 AM
casper's Avatar
casper
casper is offline
Default RE: Gauge Cluster Swap
Its all plug and play. Just get one with a tach and swap them
Old 12-30-2005, 03:23 AM
whyte69's Avatar
whyte69
whyte69 is offline
I've got the same issue on my 2nd gen neon, and I was asking around on it. Some guys were telling me that I needed a sensor and that the change would be difficult. If what they tell me is false, I'm gonna knock some skulls. I could've gone to the junkyard or some such place to pick up an old gauge. I'd like to get a tach installed on my car and I don't want to have a bulky tach sticking out on my dash, for fear of being seen as a ricer and garner unwanted attention.
Old 12-30-2005, 02:26 PM
casper's Avatar
casper
casper is offline
ORIGINAL: whyte69
Its about a 30 minute job. Plug and play.
Old 12-30-2005, 04:23 PM
catman22's Avatar
catman22
catman22 is offline
casper this may sound like a dumb question, but did some of the 95's not come with a tac wire. meaning that you would have to wire it in somehow? iseem to remember reading this in the past on this web site and the gauges will work from 95 - 99 right?
Old 12-30-2005, 06:52 PM
casper's Avatar
casper
casper is offline
I am pretty sure it will work with the 95, although I am not 100% sure. I know 96-99 is a fact, but the 95 had some odd things with it.
Old 12-30-2005, 10:10 PM
dazzellers_95's Avatar
dazzellers_95
dazzellers_95 is offline
options for the speedo 95 is tach or no tach, our pc does not interchange the two of them to fit within one another, but i am sure it will work. i have on in my 95 mtx.
Old 12-31-2005, 03:58 AM
highline95jl
Well I have a 94 AKA 95 so I decided to check into it. Ok so i called 1-800-GO-Mopar to ask if the gauge clusters are interchangeable on a 94 built 95, they couldnt tell me **** because they "only deal with parts" and im like "It is a part you dip****" So then I call the fine folks at Stever Oliver dodge here in Overland Park, and the guys like "Uhh they might be interchangeable, but I dont know" Uhh is there anywhere I can get an damn answer on weather this will work before i tear apart my gauge cluster.
Old 12-31-2005, 04:02 AM
casper's Avatar
casper
casper is offline
I am not sure. If its worth a $30 80% gonna work 20% not, those are the odds I can give you. I know for a fact it works with my 98.
Old 12-31-2005, 10:11 AM
catman22's Avatar
catman22
catman22 is offline
hell even if it dosent just plug and play the wire fix that i am thinking of is really easy to do, its harder to find the info than to do the fix.
Quick Reply: Gauge Cluster Swap
