Cylinder Misfire?! Help!!
Old 02-17-2006, 02:33 AM
highline95jl's Avatar
highline95jl
highline95jl is offline
Default RE: Cylinder Misfire?! Help!!
I have no Idea why platnum is bad but youll find your answer here. https://dodgeforum.com/m_199034/tm.htm
Old 02-17-2006, 02:03 PM
whyte69's Avatar
whyte69
whyte69 is offline
Iridium has a higher melting point than platinum, higher strength, lower resistance (2.5ohms per inch vs 6 ohms per inch with platinum), a MUCH higher hardness than platinum, and a lower required voltage to ignite.
Platinum has long been known for its durability, while Iridium is fairly new to the market. Manufacturers have had a hard time learning to create Iridium plugs efficiently enough to turn a profit. Platinum used to be the best option......until Iridium hit the market.
Old 02-18-2006, 01:16 AM
leadspud's Avatar
leadspud
leadspud is offline
I've been told when you have a coil going bad. One half of it will go bad not all of it, and this could couse a mis-fire.
Old 02-18-2006, 01:18 AM
leadspud's Avatar
leadspud
leadspud is offline
Old 02-18-2006, 10:29 AM
spudsterier's Avatar
spudsterier
spudsterier is offline
one thing you should check with the coil pack is the 3 pin flat plug on the side. if the clips are broken or loose the plug will pull away a little from the coilpack sausing it to misfire. try pushing it in just a little
Old 03-31-2013, 09:00 PM
Tracyd51's Avatar
Tracyd51
Tracyd51 is offline
Default Help
i have a 1995 dodge neon that has a misfire on cylinder 3 how do i find it....is it left to right or right to left
Old 03-31-2013, 11:20 PM
I_Ride_Neon's Avatar
I_Ride_Neon
I_Ride_Neon is offline
Holy old thread. The side with the drive belts is always the "front" of the motor. So it goes 1-4 from left to right. I believe the coil pack is also labeled.
http://www.google.com/imgres?imgurl=...QEwAA&dur=2108
Quick Reply: Cylinder Misfire?! Help!!
