fuel pump fuse
Old Mar 16, 2006 | 11:34 PM
spudsterier's Avatar
spudsterier
Default fuel pump fuse
i am just about done doing my motor and today i started the car and it ran fine, shut it off and started it agin just fine...third time it wouldnt start, checked the fuel pump fuse and it was blown, replaced at and blew again...changed pcm...still does it...the fuse wont blow when the ignition is on, only when you try to crank it over..any ideas???
Old Mar 16, 2006 | 11:36 PM
highline95jl's Avatar
highline95jl
Default RE: fuel pump fuse
Probably a wiring short.
Old Mar 16, 2006 | 11:41 PM
spudsterier
had the same problem with my red car though, found out the pcm was burnt out, cheanged the pcm, worked fine
Old Mar 17, 2006 | 12:27 AM
highline95jl
But if your already swapping out PCM's and your still shorting out fuses im gonna say your wiring is going crap on you.
Old Mar 17, 2006 | 12:32 AM
spudsterier
i know mr. smart guy, but what would exactly be the short...there is alot of different sensors that use the same circuit...im just wanting to know if anyone has any ideas what it might be.
Old Mar 17, 2006 | 12:36 AM
highline95jl
Have you tried to pull codes, or is it just blowing the fuse with no CEL?
Old Mar 17, 2006 | 01:04 AM
spudsterier
thecheck engine light is on, i am gonna hook the computer up to it tomorrow to see why, but the car isnt completely together yet, so there are plenty of things that could throw a code....but when this problem happened before i just changed out the pcm and it has worked fine ever since...i think the 2 pcms i have tried with this car are no good, i think one is a bad one from the other car...
Old Mar 17, 2006 | 03:44 AM
FuzzRacer's Avatar
FuzzRacer
my fuel pump fuse kept blowing out on me before as well, mine came from a gas leak, air was getting into one of the hoses from a small hole( would squirt out gas when shut off). I just replaced it with a another gas hose from my other neon tank and it worked out fine, then I had to just completely replace the tank with the other one because the part wear you twist the fuel pump in somehow got warped, hope some of that was helpful.
Old Mar 17, 2006 | 09:37 AM
spudsterier
yeah i am gonna have to check that out today, when my last car kept doing it it was because one of the pins in one of the big plugs that goes into the pcm wasnt making good contact.
Old Mar 17, 2006 | 11:11 PM
spudsterier
ok so i checked the codes, nothing but the battery one...replaced the fuel pump relay, still blows the fuse...no fuel leak, all wires look to be in good shape...when the fuse blows it cuts off power to the pcm and the obd-II doesnt work...says there is no connection, when you turn the ignition on you can hear the fuel pump prim itself...but once you crank it over it blows...its startin to **** me off
