99 neon ...... srt-4 turbo help??
RE: 99 neon ...... srt-4 turbo help??
ORIGINAL: HabitatHxC
Where does the RRFPR go?
Where does the voltage clamp go?
Click on products, then signal clamps, and then on VC1 Voltage Clamp.
i am in the same predicment you are. my buddy told me that it only works with a dohc because i am looking for a new car and he was like buy a 1st gen neon but make sure its a dohc and he would sell me his stock turbo and manifold. i am new to the forums can you explain to me how to post messages like this and stuff? thanks
no it isnt a good idea, but you can do it.....just maight cause you some problems....
the turbo will work on a sohc, but you need an adapter....the turbo should hold a higher gain on a dohc anyways
to post just go to the top of the main page and click on the NEW POST button
if you need any help, i have alot of pics on here floating around
ORIGINAL: FastNeon84
so its not a good thing to run the Mopar Performance PCM with turbo?
ORIGINAL: das2123
Do not use aftermarket PCM's with a turbo.
