Wheel Hop?
Old 08-16-2006 | 03:58 AM
fetus's Avatar
fetus
Default Wheel Hop?
I think i have wheel hop. It is pretty bad. Front end has lifted off ground before. What are all the possibilities to fix wheel hop this severe?
Old 08-16-2006 | 04:05 AM
NEONRT98's Avatar
NEONRT98
Default RE: Wheel Hop?
Describe this "wheel hop"..
Old 08-16-2006 | 04:22 AM
fetus's Avatar
fetus
shakes up and down from a launch. sometimes it does it when changing into 2nd gear while driving normal (automatic)
Old 08-16-2006 | 04:27 AM
FuzzRacer's Avatar
FuzzRacer
as in driving up an incline correct?
Old 08-16-2006 | 04:33 AM
fetus's Avatar
fetus
no..as in driving regular from a stop 1st to 2nd gear
Old 08-16-2006 | 04:53 AM
dogdaysunrise's Avatar
dogdaysunrise
like it bounces up and down, as would say a manual that isnt getting enough gas?
Old 08-16-2006 | 04:57 AM
fetus's Avatar
fetus
yes it bounces up and down. what do you mean "as would say a manual that isnt getting enough gas?"
Old 08-16-2006 | 06:16 AM
spudsterier's Avatar
spudsterier
wheel hop happens usually when a 5-speed launches when spinning the tires....it causes the whole front end to studder.....almost any neon owner that has spun the tires in there car has experienced wheel hop......easiest way to eliminate some wheel hop is with solid motor mounts or upgraded axels......wheel hop will usually occur because the tires grip and loose traction over and over, due to alot of the fact of not enough weight on the front of the car....
you will not usually encounter wheel hop in normal driving conditions....
other things can make your car seem like it has wheel hop....bad clutch, bad driver, bad torque convertor, bad motor mounts
Old 08-16-2006 | 06:28 AM
fetus's Avatar
fetus
thanks you spudsterier. would a bad bobble strut do it? which motor mounts could cause it? could just 1 bad mount cause it? My front motor mount looked pretty worn out. I ordered a new performance 1. I hope this fixes it. and like i siad its an automatic, i dont think its a bad clutch. lol
fetus's Avatar
fetus
Quick Reply: Wheel Hop?
