99 dohc engine put into a 98 dodge neon r/t overheating
Old 10-20-2006, 05:15 PM
ravageneon's Avatar
ravageneon
ravageneon is offline
Default 99 dohc engine put into a 98 dodge neon r/t overheating
I have a 98 dodge neon r/t that i droped a 99 dohc engine into. the engine has like a 180,000 miles on it. the timing belt blew on me and the valves and timing belt were replaced.The problem is that it overheats on me!
the parts that i have changed are as follows
1. thernostat twice
2. put a used radation into it
3. i have the fans wired up so the can be on all the time
4. changed the ressivor
I am thinking that i have to chane the water pump but am hoping not??
any suggestions??
Old 10-20-2006, 05:24 PM
ZiggyNeon's Avatar
ZiggyNeon
ZiggyNeon is offline
Default RE: 99 dohc engine put into a 98 dodge neon r/t overheating
any oil in your coolant?
Old 10-20-2006, 05:27 PM
ravageneon's Avatar
ravageneon
no there is no oil in my coolant? but i do heaar it boiling from the resivor when it overheating or warm!
Old 10-20-2006, 05:41 PM
das2123's Avatar
das2123
das2123 is offline
What about your CTS?
Old 10-20-2006, 05:42 PM
ravageneon's Avatar
ravageneon
what do u mean cts
Old 10-20-2006, 05:51 PM
das2123's Avatar
das2123
das2123 is offline
ORIGINAL: ravageneon
what do u mean cts
Coolant Temp Sensor
Old 10-20-2006, 05:56 PM
ravageneon's Avatar
ravageneon
where is it located in a dohc engine??
Old 10-20-2006, 06:09 PM
ZiggyNeon's Avatar
ZiggyNeon
believe its on the right hand side of the engine if your standing in front of it looking at it lower area
Old 10-20-2006, 06:14 PM
ravageneon's Avatar
ravageneon
i found what apears to be a sensor located next to the thermast. has a connector plug with 3 pin in it and and threaded ends
Old 10-20-2006, 06:27 PM
FyreDaug's Avatar
FyreDaug
FyreDaug is offline
thats the one, it was a 40 dollar part for a SOHC up here in canada, I just replaced mine 2 days ago
Quick Reply: 99 dohc engine put into a 98 dodge neon r/t overheating
