SRT Turbo Checklist
#21
RE: SRT Turbo Checklist
sumthing else that i found you have to do is get the stock srt oil return line.....take off the rubber part so that you have just the metal tube.....then you have to make a few bends in it so that it clears the axels and the exhaust.....i bent mine a little and connected a rubber hose to it and then ran it between the steering rack and the cross member.....then to the oil pan...i will get some pics of what i mean soon
#22
hey i'm turboing my 1995 i donno what the hell to do and and looked at the check list so i would need the sohc to dohc adapter and the pieces?? cuz i;m lost as hell on this on just sent me an mxpx_400@hotmail.com
#24
ORIGINAL: dulmage
1. buy the $220 adapter
2. buy top end dohc pieces (lower compression, higher boost)
3. drop in a dohc motor
otherwise if you have a dohc ignore that box
#25
#26
#29
an auto turbo isnt too bad....but a 5 speed would still be better....
the only adapter that i have heard of is for the dohc-sohc.....but none else........it would deffinately have to be custom
srt turbos are all over ebay......and check srtforums.com......you can usually find them for about $200.00-$250.00 shipped
#30
