steering
Old 11-10-2006, 06:37 PM
Allnbrgdn1's Avatar
Allnbrgdn1
Allnbrgdn1 is offline
Default steering
my power steering went out today,can anybody give me any advice?
Old 11-10-2006, 06:55 PM
das2123's Avatar
das2123
das2123 is offline
Default RE: steering
ORIGINAL: Allnbrgdn1
On what? What went out, pump/belt?
Old 11-10-2006, 07:56 PM
Allnbrgdn1's Avatar
Allnbrgdn1
i dont know, when im moving slow is when it gives me the problem
Old 11-10-2006, 08:12 PM
Allnbrgdn1's Avatar
Allnbrgdn1
belt is still in place, is there a way to trouble shoot the pump? and would i still be able to steer at high speeds?
Old 11-10-2006, 08:44 PM
FyreDaug's Avatar
FyreDaug
FyreDaug is offline
yeah power steering is really "power assist" after you get up to a certain speed the power steering is basically bypassed anyways. High speed driving would be fine
Old 11-10-2006, 10:21 PM
Allnbrgdn1's Avatar
Allnbrgdn1
do u think its the pump?
Old 11-10-2006, 11:10 PM
spudsterier's Avatar
spudsterier
spudsterier is offline
could be the pump, or steering rack, or just might need new belts
Old 11-10-2006, 11:32 PM
pimpberetta's Avatar
pimpberetta
pimpberetta is offline
Check your fluid levels for sure, maybe a gasket has gone out.
Do you hear any whining?
Old 11-11-2006, 10:08 AM
Allnbrgdn1's Avatar
Allnbrgdn1
i dont hear any whining, is there a way to check the pump before i replace it?
Old 11-11-2006, 10:29 AM
spudsterier
i had a problem a while back with my pump.....the retainer clip that holds the pulley and inner shaft broke, so you could slide the whole shaft and pulley out of the pump...even with the belt on, but i highly doubt thats your problem
Quick Reply: steering
