sohc or dohc
sohc or dohc
sohc or dohc whitch is beter for racing the risson i ask is cuse im going to beld a motor from the ground up and i want to know witch is better for racing im planing on running turbo im just curious on witch head is better im open for ideas on every thing from hoses to pstons to spark plugs
RE: sohc or dohc
in the end, both are good for drag racing. the fad for now is a stratus 2.4l block with a magnum head and intake. dont ask me, as i am sohc all the way. i will still be tearing down others in it til the day i retire. sohc are easier to tune as only 1 cam gear, put out about the same amount of power ect ect, the doh and soh blocks are the same, pistons between the 2 are different and of course the heads. if you want gobs of power, 2.4l stratus or pt cruiser engine with a magnum head i would guess.
Trending Topics
RE: sohc or dohc
ORIGINAL: spudsterier
but extra stuff can be done to the dohc that cant be to the sohc.....such as port and polishing the intake manifold
RE: sohc or dohc
ORIGINAL: das2123
You can port it the plastic manifold and there is an aluminum SOHC manifold out there that we can port/polish also. SOHC people can also use the magnum head and/or intake. So we have possibilities also
