Looking for advice and suggestions
Old Mar 8, 2011 | 09:21 PM
  #31
SixGun's Avatar
SixGun
Nice shifter - did you make it or buy it somewhere?
As far as cupholder goes, isn't that what the wife's for?
Old Mar 8, 2011 | 09:41 PM
  #32
crazzywolfie's Avatar
crazzywolfie
my dad use to just set his drink on the dash. as long as he never had a "watch this" moment it was fine. i have seen some people buy a cheap center console and cut it up to make it fit nice on the floor.
Old Mar 8, 2011 | 10:37 PM
  #33
Big-D_1823's Avatar
Big-D_1823
Bought the shifter at autozone and after a few adjustments to the instalation kit, it fits pretty good. Alright i'll see what i can find and get back with more updates.
Old Mar 9, 2011 | 08:22 AM
  #34
SEAL's Avatar
SEAL
I put 3 cheap plastic cup holders in my truck. If you lift the vent window weather stripping you can hook one between the weather strip and the door metal on each door. I hooked one between the dash and the gage trim piece just above my ac/heater controls.
Old Mar 10, 2011 | 10:33 PM
  #35
Big-D_1823's Avatar
Big-D_1823
hmm might have to look into that idea too. I'm thinking about getting a 2 or 3 inch lift. What y'all think?
Old Mar 10, 2011 | 11:20 PM
  #36
Big-D_1823's Avatar
Big-D_1823
add on to my last question, which should i get, body or supension lift kit. I'm mainly looking to add bigger tires and just give it a little general height, not looking to go off roading.
Old Mar 10, 2011 | 11:42 PM
  #37
crazzywolfie
a body lift would probably be easier since it is a lot harder to find a suspension lift for the front.
Old Mar 11, 2011 | 11:53 AM
  #38
Big-D_1823's Avatar
Big-D_1823
well i think im going suspension anyways. Everyone i've asked said to go suspension because bodylifts mess up a lot of things. Its more expensive but oh well. Anyone know any good brands that work well?
Old Mar 11, 2011 | 12:40 PM
  #39
82ram150's Avatar
82ram150
Ive been thinking of lifting mine too since the front sits lower than the back. I heard you can put 1 ton springs up front to get I think one to two inches of lift. But I believe they are siffer. Summit racing sells shocks than give you 1-2" of lift too. I'd like to do a body lift with it also. The only one I found was 3" at summit racing I think for $168. I'd rather have 1.5-2".
Old Mar 11, 2011 | 01:51 PM
  #40
crazzywolfie
if you get a suspension lift it messes up a lot of things too. usually if you get a suspension lift in the front you will have to take you truck to have a front end alignment done.
