Location of ECM?
I am hoping it is not bad. I am going to check it out today to make sure their is no visible burnt wire or plastic.
Over the past year the truck has developed a "dead spot" in the throttle. If you BARELY foot your foot on the gas in park, neutral, or reverse, and hold it there it will stall. It does it more or less in reverse. I step on the gas in reverse it moves a few feet, drops rms, sometimes it will catch it, self sometimes it will stall. I does this in drive also.
I had the transmission rebuilt about 9 months ago. The problem just started getting REALLY bad these past few months. So to try and fix the problem I have replaced the TPS sensor, MAP sensor, IAC control valve, speed control sensor, and camshaft sensor, taken the throttle body off and cleaned it and put in a new battery. I have also replaced the fuel pump and fuel pressure regulator. I have sprayed seafoam through the intake, put seafoam in the gas tank, put Marvel Mystery Oil in there drove it for a few days and no change. I have checked the transmission fluid level and it is full. I recently did a tuneup plugs, plug wires, cap and rotor. I have also replaced the EGR Valve.
So as you can see, it seems like it could be an ECM problem. I am hoping that it is not. I would appreciate an alternative though lol. I've already put too much dang money into this thing.
Trending Topics
Lol I had to go out and get the paperclips and voltmeter. The TPS sensor is fine the ECM wasn't throwing any codes. I took it over to my diesel mechanic friend and after looking at it for about 30 minutes we found that the harmonic balancer was wobbling. So if that is wobbling its throwing the crankshaft sensor off. So we are going to replace it this afternoon. I am pretty sure we nailed it this time.
