A/c ??
Old Jul 29, 2011 | 01:44 AM
  #31
SixGun's Avatar
SixGun
Nope, AC is not working yet. I really think I might do some suspension work next like new front coils and add-a-leaf in back first. If I get too comfortable, I might start kicking back. Ha ha...
I took it on a little adventure to Medina Lake the other day when I was on vacation. The longest drive it's been on in a couple of years. A few hiccups on the drive but nothing major.
Old Jul 29, 2011 | 02:16 AM
  #32
crazzywolfie's Avatar
crazzywolfie
what type of add-a-leaf where you thinking of adding. i like home made add-a-leaf kit the previous owner installed in my 81. it looks like they cut the ends off a main leaf spring and installed it under the main leaf. they also shortened another leaf and installed it under one of the other leafs.
Old Jul 29, 2011 | 09:20 PM
  #33
aje1127's Avatar
aje1127
hey sixgun,
truck body looks nice and straight,even tailgate. is the engine broke in yet from the rebuild?? it will run a lot better when you start running it more and get some miles on it. thank you
Old Jul 30, 2011 | 01:30 AM
  #34
SixGun's Avatar
SixGun
Hey Aje,
I'm still taking it easy for the break in. I bought a newer CD player and put in 2 more speakers. Put in a vacuum gauge and tach recently. I really want to put in this old siren from a 72 Chrysler New Yorker old school car alarm. It is loud as hell like an air raid siren.
Wolfie,
For the coils, I was originally going to go with Eaton but read a lot of good things about Coil Spring Specialties customer service dept. and they are a little cheaper too. As far as add-a-leaf, I probably will go Rancho but I've used Pro-Comp before and liked them. Still debating the long leaf vs short leaf. Home-made, I feel would be twice the trouble since I don't have a set laying around. With store bought, I just have to do the labor once.
Old Aug 28, 2013 | 02:00 PM
  #35
wllilly's Avatar
wllilly
having same problem finding cycling switch no.56005783 looks like someone should make one if dodge won,t handle them anymore
Old Oct 20, 2020 | 02:59 PM
  #36
Brett Rossi's Avatar
Brett Rossi
Hey! I did a ton of looking around also, since I narrowed it down to this same exact problem. most likely just the diaphragm in the old switch. Really annoying that it comes down to this one cheap part and can't seem to find it anywhere. I am wondering, however, if an aftermarket one will work if the cut off switch is rated at the same PSI???
Old Oct 20, 2020 | 04:22 PM
  #37
Advance auto has generic fellers. Should have one for ya.
