dodge w100 custom '84
Old Aug 12, 2011 | 12:59 AM
astraone's Avatar
astraone
Default dodge w100 custom '84
trouble with the fuel stopping at random times, im a canuck who prospects. new carb and lines. any ideas? 5.2L
Old Aug 12, 2011 | 07:51 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. You could check in the Ram or Pwer Wagon section if they are related to the W100,
FF
Old Aug 12, 2011 | 01:46 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Enjoy the site!!
Dusty
Old Aug 12, 2011 | 02:02 PM
vpnavy's Avatar
vpnavy
Welcome aboard astraone! Like fascistfaction suggested - don't forget to browse Sub-Forums: Ram for stuff related to your ride.
Old Aug 15, 2011 | 09:17 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
Can you please elaborate on what you mean by stopping the fuel?
Old Aug 16, 2011 | 12:55 PM
astraone's Avatar
astraone
Default fuel
cruisin down the road and the truck quits. replaced the carb, fuel pump, fuel filter, fuel lines and it still does it. you stop, and check; fuel still in carb or squirting in but the truck fires up again and down the road quits again. coil maybe? fuel sending unit? got me stumped.
same block 318 as in my stock cuda but different configureation
Old Aug 16, 2011 | 07:27 PM
1969CoronetR/T
vaffanculo
It may need a ECU as my Coronet would die for no apparent reason. I am not sure how to check though,
FF
Old Aug 17, 2011 | 02:47 PM
astraone's Avatar
astraone
Default Ecu
what is this? moderator please move from intro to appropiate categorie
Old Aug 17, 2011 | 07:40 PM
1969CoronetR/T
vaffanculo
http://en.wikipedia.org/wiki/Electronic_control_unit
Moved to first generation Ram section,
FF
Old Aug 18, 2011 | 06:07 AM
SEAL's Avatar
SEAL
I have read nothing that points to a fuel problem. This also doesn't sound like a coil failure. If the truck starts up immediately there is only one way to trouble shoot this problem, as much as I hate it, and that is parts replacement. I would start with the ECU because they are trouble prone and cheap.
