no charge !! 84 d-250
Old Sep 20, 2011 | 05:58 AM
  #41
jasonsxj's Avatar
jasonsxj
Originally Posted by psycobilly64
You should only have power at the top terminal with the key on. If you have voltage at both, something is wrong and that will cause it to pop the new reg as soon as you turn the key on.
Well I have the key switch power coming from the fuse block then teeing off and one going to the vr and one going to the alternator and the green field wire going from alternator to the vr.Is that right?
Old Sep 20, 2011 | 02:45 PM
  #42
snobuster's Avatar
snobuster
Do you have a manual for your truck? I had the same problem with my 85 d350 dually and i replaced the alternator, voltage reg, still no charge, had alt tested ok, so I went thru the complete test procedure in the factory manual, found the new vr was bad. When it was replaced it was charging. I can e mail you the test pages from my book it you need them
Old Sep 20, 2011 | 03:47 PM
  #43
jasonsxj's Avatar
jasonsxj
Yes I do have a actuall 84 shop manual! I was thinking about adding more grounds.what's a good spots to add grounds to? ? Right now I have one from the starter to the frame" braided " one from negative sided of battery to radiator support, and of course the negative battery cable to the block. Thanks guys for all your help
Old Sep 21, 2011 | 01:34 AM
  #44
HAzMAT09's Avatar
HAzMAT09
I have always tried to ground as much to the frame as I could. makes it easy to reach in case I have an issue.
Old Sep 21, 2011 | 06:54 PM
  #45
psycobilly64's Avatar
psycobilly64
So you have voltage running to the alt in more than one place? If so that may be your problem. The voltage to the alt should only be at the large bolt on the back of the alt. The 2 field current wires go to the reg with an ignition pos to the top pole of the reg.
Old Sep 24, 2011 | 06:14 AM
  #46
jasonsxj's Avatar
jasonsxj
Well I finally got the old truck charging . I guess through all the testing and retesting some how the two vr wires got crossed and kept blowen the vr's so I fixed that and with a new vr I am getting 13.6 at idle! !! Finally I can drive the ole truck! ! Thanks guys for all your help and patience.
Old Sep 25, 2011 | 05:45 PM
  #47
psycobilly64
Glad to hear it man! Congrats and glad we could be of help.
