relay locations 1991 Dodge trucks
Old 09-25-2012, 04:23 PM
Sniper X's Avatar
Sniper X
Sniper X is offline
Default relay locations 1991 Dodge trucks
Is there a print out or picture of where all the relay locations are for the 1991?
Old 09-25-2012, 06:05 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
Old 09-25-2012, 06:17 PM
SEAL's Avatar
SEAL
SEAL is offline
You may or may not have all 4 relays. I have 3.
Old 09-26-2012, 10:37 AM
Sniper X's Avatar
Sniper X
Sniper X is offline
THANKS! Is the auto shut down relay the fuel pump relay? I was having trouble starting the truck intermittently, changed out that relay, and now it starts every time.
Old 09-26-2012, 10:41 AM
SEAL's Avatar
SEAL
SEAL is offline
The fuel pump is controlled by the ASD along with other things.
Old 09-26-2012, 06:02 PM
Sniper X's Avatar
Sniper X
Sniper X is offline
Well, I can tell you that that relay was the problem. It went intermittent, and it stopped me from being able to get the truck started about every 4th time I jumped in the truck. I figured it out when I opened the hood, tapped on the three relays and it fired right up. When it happened again I tapped on each separately till it fired up and guess which one I had to tap on to get it to start?
Old 09-26-2012, 06:18 PM
crazzywolfie
so did you finally replace it and solve your problem?
Old 09-26-2012, 09:35 PM
Birge's Avatar
Birge
Birge is offline
What does the part throttle unlock relay do
And can this be posted in the sticky
Good info
Old 09-26-2012, 09:47 PM
crazzywolfie
i have tons of pictures that should be posted in the diy sticky but i have never got around to it.
these are just the ones that i have labled
https://picasaweb.google.com/Hammond...eat=directlink
Old 09-27-2012, 10:43 AM
Sniper X's Avatar
Sniper X
Sniper X is offline
Me? Yes indeed! I had about 5 compatible Bosch 4 prong relays configured the same was pin wise and just swapped one in and it was all good! ANY bosch type 4 prong relay wired right will work in that application.
Quick Reply: relay locations 1991 Dodge trucks
