1984 W 150. 318 2 barrel.
Old Mar 27, 2013 | 08:21 PM
deadline69's Avatar
deadline69
Default 1984 W 150. 318 2 barrel.
Just bought this truck and it has very speratic idle rpm's. There is a new ignition modual, balast, coil, rotor , cap , . The carb and fuel pump and distributor are the only three old things on the engine. When driving forward at less than five mph, I let off the gas quickly and press the brake firmly , not hard , and the engine will die. No puttering just dead . should I even bother trouble shooting it or just replace all three things and if it keeps doing it then trouble shoot. . Thanks a bunch, and money is no problem just would like some spitballing ideas of What u guys think. P.s. There is some back fire through the carb at idle , when im reving it. Also when I punch the gas it gulps ,almost dies and then revs up.
Old Mar 27, 2013 | 08:39 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Sounds like you've got a vacuum leak.
I'm currently having to deal with a lighter variant of what you've got.
Old Mar 28, 2013 | 01:09 AM
deadline69's Avatar
deadline69
Yeah but I am spraying the carb down with carb cleaner and im not noticing any difference. Maybe I should invest in a vacum gauge/tester
Old Mar 28, 2013 | 03:03 AM
dodge dude94
It's not just your carb, it could also be anyone of the blasted vacuum hoses strewn about the engine of the mid 80's Dodge.
Old Mar 28, 2013 | 07:00 AM
deadline69's Avatar
deadline69
Should I just rip all the vacum hoses out and just keep the pcv , and vac advance??. & plug all the other ones
Old Mar 28, 2013 | 08:06 PM
jasonw's Avatar
jasonw
Site Moderator
Future reference:
https://dodgeforum.com/forum/dodge-r...s-section.html
Old Mar 28, 2013 | 08:12 PM
dodge dude94
lol
No, you should start checking then and what ever ports are plugged, for leaks.
Old Mar 29, 2013 | 07:14 PM
deadline69's Avatar
deadline69
Brand new carb, and it idles very calmly at about 600 750. When driving forward and I apply heavy braking it dies, and when in gear the rpms are all over the place. Could the pickup be going bad or the ignition module????. Should I be getting constant steady voltage from the ballast or spiratic voltage im talking +- a few volts. ????
Old Mar 29, 2013 | 07:20 PM
crazzywolfie's Avatar
crazzywolfie
did you tune the new carb? 600 rpm is a bit low. it should probably idle in the 750-1000 rpm area.
Old Mar 29, 2013 | 07:34 PM
deadline69's Avatar
deadline69
Didnt mess with it. Its straight ftom the factory. ill turn it up. But it wont make a difference because it still shuts off when on high idle with choke.
