Revisiting trans/engine swap
Old May 9, 2013 | 08:50 PM
  #81
Comrade General's Avatar
Comrade General
I was thinking if I get headers Ill wrap them or get ceramics.
wombat, what were some issues you had on your swap? Im sure they will be some and I would like to get extra parts or whatever I may need before that way we dont tear it aprt and break soemthing then both my trucks are undrivable until we get the part. Mainly I thinking hardware wise.
Old May 9, 2013 | 09:23 PM
  #82
Wombat Ranger's Avatar
Wombat Ranger
I replaced the nv4500 that was in my '95, I didn't do an auto to manual swap. So I know how the install goes. I haven't done a swap before but I can't see it being that big of a deal.
If you have a mpi motor don't swap to a carb. Mpi is a much better system. If you have tbi then swap away.
Old May 10, 2013 | 12:06 AM
  #83
Comrade General
oh ok.
And yeah I got MPI
Old May 10, 2013 | 10:41 AM
  #84
Sniper X's Avatar
Sniper X
Manual to auto is easy compared to the other way round. You can use the same pedal pack just the clutch doesn't work, and install a cool floor shifter in the hole the 4sp rod came thru.
Old May 10, 2013 | 04:30 PM
  #85
Comrade General
Cool cause after I swap my auto for a manual I want to put my auto in the donor truck so its drivable
Old May 11, 2013 | 02:01 PM
  #86
Comrade General
So ive been looking at rock auto to order new seals so they can be at least changed out and all their seals say for 4 speed transmissions
http://www.rockauto.com/catalog/x,ca...mission-Manual
Old May 13, 2013 | 11:14 PM
  #87
Comrade General
Anybody know anything about that? ^^
I think there might be something wrong with the transmission. Was driving the donor today and noticed a grinding/rattling sound coming from the tranny. Didnt start til after I shifted into 5th
Old May 14, 2013 | 05:17 AM
  #88
crazzywolfie's Avatar
crazzywolfie
did you make sure the oil level in the transmission is where it is suppose to be?
Old May 14, 2013 | 04:58 PM
  #89
Comrade General
No, not yet. Will check it though
Old May 20, 2013 | 01:51 AM
  #90
Comrade General
That fill plug was on there tight. I couldnt feel any oil in the tranny. I plan on opening the drain valve when I get the time to see if any drains out. To know if there was at least some in there.
