Revisiting trans/engine swap
So awhile back ago I was very close to doing an engine swap from 318 to 360. I am revisiting that idea except this time I am looking more into an auto to manual swap.
I want to go to a 5 speed (vs 4 speed). If anyone has done anything with 6 speeds Id be interested in that aswell. I recently found a posting on CL with the Getrag 5 speed for sale along with all the parts to do a manual swap. The getrag was attached to a diesel 360. So my question are:
-Will this getrag only match up to a diesel 360 or will it match with a gas 360 too?
-Will the getrag mate with a 318? (if I decided not to swap engines)
-Also is the getrag even worth swapping too? Ive seen alot of people talk about the nv4500 which I hear is really good but is there a big difference?
-The CL says its only for a 2wd truck? Does that really matter?
CL link for reference: http://seattle.craigslist.org/est/pts/3718942196.html
FYI my truck: 1992 w150 318 auto trans.
i don't think that would work. you need one out of a gas 4x4 truck. to even make a 2wd trans work with a 4x4 is a lot of work. trying to make a diesel transmission work would complicate things even more unless you plan on dropping a diesel in it.
http://seattle.craigslist.org/oly/pts/3716479320.html
Found that link on CL. Not sure what trannsmission that is. Ill probably give him a call soon.
Does anyone have a list (or know where one is) for all the parts needed to convert from auto to stick?
Trending Topics
http://ramchargercentral.com/diesel-...ks-to-threads/
Hmm. I might have to look into it
http://seattle.craigslist.org/tac/cto/3719334337.html
Should I even consider getting a 4 speed truck?
http://seattle.craigslist.org/sno/cto/3731817113.html
Found this looking around. Im partially tempted to go check it out. Ext cab, 4x4 cummins. Only thing it needs is a 5 speed
If you want to do a swap to put a manual in your truck the easiest way would be to find another truck for a decent price with a manual in it and then you could swap all the parts. you said in your first post something about wanting to go to a 360 as well, so if you bought a truck like the 4 speed one you posted above then you could use what you want from the 2 trucks to make the truck you want.
From what I gather on here and other websites a 4 sp to 5 speed swap is pretty simple so after converting to a manual if you find a 5 sp you could upgrade, and apparently even use the same clutch from the 4speed.
I would think the biggest probl;em with swapping a diesel into a gas truck would be the weight of the engine apparently they weigh a lot and diesel trucks have some different parts in the front end to accomadate.
