Spool/locker 9.25
They may not have, but I have seen some 8.75 with lockers in them on CL, but they have really tall gearing, like 2.73 tall lol. What about a Dana 44?? Found a few of those. I'm just trying to see what my options are, might just go with a Ford 9" parts plenty, and easy to find.
Little pricey, about $580 without installation parts, and gears..........I think I'll keep scouring Craigslist, something will pop up eventually. How much of a pain is it doing an 8.75 swap? Or a newer 9.25 from a mid 90s up 1/2 ton w/disc brakes? And that is a future mod, 4 wheel disc brakes. Just gathering info. Nothing is set in stone.
the stock limited slips are not bad if they are maintained properly with the special limited slip additive that most people don't usually use when they do an oil change and burn up the LSD. i got 2 stock LSD's and they both still work as they should
that is why i was thinking lunchbox locker. will most likely be the best bang for your $$. you can get disk brake conversion kits for the axle that is in your truck.
i don't know how the dana 60's don't require it but the 9.25's do. you would think they all work the same and require the additive to function properly. that is why i was thinking lunch box locker. practically they same as welding the gears without welding the gears and you can install it in your driveway in a hour or so. they can also be had for pretty cheap compared to replacing the whole differential assembly.
looks like summit only carries a few for the 9.25 but this one seems to have pretty good reviews.
https://www.summitracing.com/parts/pwt-92-0392-3105
Your 05 Ram 2500 doesn't have a Dana 60, 02 was the last year Chrysler put Dana axles in the HD rams, 03 and newer have an AAM 9.25 front and either an AAM 10.5 or 11.5 rear axle. The reason they don't require the additive is because they use a gear driven limited slip similar to a Detroit Truetrac, that doesn't have clutches. Clutch type limited slips wear out no matter if you use the additive or not, all the additive does is allow the clutches to slip easier, making the unit less effective. For a lunchbox locker I believe Powertrax is the only company that makes one for the Chrysler 9.25.
