1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hey, I have a 1988 Dodge 2wd pick up with a 3 speed automatic and the 318. It’s a no overdrive version. It drives perfect and looks great. It has a completely overhauled tranny and newly fabricated TC. When you put it into reverse without holding the gas it will jerk and die. It’s done this since before changing the tranny. Any ideas? Thanks
does a bit more throttle when in reverse keep it going? i would wonder if the idle speed needs some tweeking or maybe the idle speed motor is a bit slow.
don't just go and try to turn the idle up. it is not that simple. there is a whole procedure to make sure it is adjusted properly. also the idle control motors are know for going bad or getting slow with age. might be worth opening it up and cleaning/re greasing it.
