Won't Start After Getting to Operating Temp
My 1985 Dodge D150, with a 1979 318 engine, won't start after getting to operating temperature. It's suppose to have a three way fuel filter on it,
but someone before me put on a regular inline fuel filter and then plugged off the third line. I'm thinking it could be vapor locking. I was also thinking
it could be the distributor pickup coil. Does anyone have any suggestions? Also, anyone have any idea where the EGR valve is supposed to plug
into? Whoever had this truck before me, really did a number on it. I been working on it for nearly 2 years now, and I almost got it. I just need to
figure out why it won't start after getting to operating temperature. Any suggestions will be greatly appreciated.
Thea
Thea
Engine needs three things to run, fuel, spark, and air. You are missing at least one. See which one it is.
Why would it have fuel, spark, and air when it's cold, but not when it's at operating temp? That just doesn't make sense, so there has to be something
else that's preventing it from starting when at operating temp. I've changed the coil, rebuilt the carb, did a tune up, put on a new fuel filter and replaced
the thermostat. A couple of people from around my town mention the pickup coil. Could the pickup coil in the distributor be the problem?
Some variety of electronic ignition? Something is getting hot, and failing. You can bet your bottom dollar that's an electrical part. Not sure what all your ignition system involves though..... If there is a smartbox on the firewall for it, that would be a suspect as well.
Trending Topics
i would guess it is likely a fuel related issue. which carb is on it? i don't know if you have access to it but might be worth trying ethanol free gas if it is available locally. will it start if you pump the gas after cranking it for a few seconds?
https://www.pure-gas.org/station/7252
After it won't start check to see if you have spark. No spark then you know it's in the ignition system. If it has spark spray some stating fluid into the carb and see if it starts. If so then it's in the fuel system. And check the choke to see if it's sticking and not opening all the way after it's hot.
