Misfiring
  #21
Old 01-29-2023, 04:38 PM
Healed's Avatar
Healed
Healed is offline
I really don't know how to do that. It won't run but it sounds like all of them are misfiring. And when it finally dies, the injectors are all clinking. I can hear them and feel them when I put my fingers on them. What would cause that. It does this randomly.
  #22
Old 01-29-2023, 04:41 PM
Healed's Avatar
Healed
Healed is offline
I made a typo. I meant the injectors are clicking.
  #23
Old 01-29-2023, 07:12 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,235 Likes on 2,984 Posts
Reset the computer. (just disconnect the battery, turn on the headlights, turn off the headlights, hook the battery back up.) give it a crank, see what happens. Might also try holding the gas pedal to the floor and crank it.
  #24
Old 01-29-2023, 10:00 PM
Healed's Avatar
Healed
Healed is offline
Ok, I will do that in the morning. Thanks
  #25
Old 01-30-2023, 03:00 PM
Healed's Avatar
Healed
Healed is offline
Well I did what you said to do and it wouldn't start.
  #26
Old 01-30-2023, 06:13 PM
HeyYou is offline
Is it flooding out? Or is it just not firing the plugs? If you have regular champions in there, I have seen them get flooded once, and never fire again.....
  #27
Old 01-30-2023, 06:50 PM
Healed's Avatar
Healed
Healed is offline
No it's not flooding out. I don't use champion for that very reason.I had a 70 Cuda with a 440 6 barrel stroked to 500 cid. That broke me from using champion. I didn't check to see if it was still getting spark to the plugs or not. I will do that tomorrow. Thanks
  #28
Old 02-04-2023, 06:00 PM
Healed's Avatar
Healed
Healed is offline
Well I checked to see if it is getting spark and it is not getting spark from the coil to the distributor. It is still getting 12 volts to the coil when I first turn the switch on.
  #29
Old 02-04-2023, 06:04 PM
Healed's Avatar
Healed
Healed is offline
What would cause the injectors to click while the switch is on and the engine not running? It's not doing that now but that's what always happens when it stalls.
  #30
Old 02-04-2023, 08:51 PM
HeyYou is offline
Low voltage is a possibility. Do they continue to click after the engine has stopped?
Quick Reply: Misfiring
