Front brakes overheating
I just changed the front brake pads last thursday. They seemed to be working great until yesterday I had to go somewhere and there where alot of big long downgrades. I had to follow a guy on a motorcycle that was driving like a grandma so I had to use the brakes alot. By the time I got to the bottom, The brakes stunk so bad and I had almost no brakes. I used the pads that autozone had in stock. Semi metalic and they were just under $40. I threw the box away because they were working fine. I did not turn the rotors because they looked perfectly fine. They weren't gouged or glazed over.
All I did to change the pads was, Take the caliper loose remove the outside pad and use a c clamp to compress the piston with the old inner pad still installed. I then removed the inside pad and installed the new ones. Put the first side back together and then pushed in the brake patal to make sure the piston went back out evenly. Repeated this on the other side and all worked great. I've done this a million times for every vehicle I've owned. The only thing I noticed that was odd to me was when I finished up and went to put the cap back on the master cylander (fluid tank) I noticed that the brake fluid was way over filled now. I removed enough fluid to get it down to the full mark and left it be. I figured it was just because the old pads where only a 1/4 thick and the new ones where about 1 inch thick. Well anyway, thats my story and I'm sticking to it. I didn't notice anything leaking anywhere, the petal feels really stiff the way it should, and doesn't fall or sink while idleing. Any ideas, I was thinking that maybe the rear needs to be adjusted.
They are Duralast Gold, I got them from Advanced Auto for $38.99 there where three other brands below them. I was going to order the Raybestos but I didn't want to have to go back. All the pads looked the same and after I installed each side I pressed the brakes to make sure they went to the pads. Maybe they could be sticking to and the pistons not lettijng them release right but I'll have to check that out. Any other ideas?
Trending Topics
ORIGINAL: imnothot02
find alot of DIY think they can own a 100 piece tool set guys that dont know they need to do that...[:-][:-][:-]
we had a kid come into NTB the other day driving a v6 99 mustang or some ****, and he did his own brakes, new pads, rotors the big deal.. came in 2 hours later and the damn rotors where so hot we coudnt turn them.. the kid used NO lube what-so-ever.
He told us the whole story to.. kinda funny he knows he is an idiot and brags about it.. gota love ford drivers.
