i finally did it!!!
Old 07-02-2007, 03:20 AM
boohoops's Avatar
boohoops
boohoops is offline
Default i finally did it!!!
i finally hit my speed limiter! i got my98 r/tin january and it took me till now to reach tht limiter..shut off around 117-118...ive been 110 and 115 in it but nevr got to that limiter..i dont kno y it shut offbecuz i kno th engine could handle way more
Old 07-02-2007, 04:02 AM
f0x672's Avatar
f0x672
f0x672 is offline
Default RE: i finally did it!!!
yea im speed limited at 115... were limited so we dont kill ourselves and dont overspeed the drivetrain i beleive... mainly so we dont kill ourselves
Old 07-02-2007, 04:09 AM
takethebounce's Avatar
takethebounce
takethebounce is offline
I had my 3.9 doing205 km/h which I believe is over118 mile/h and it never hit any limit that I know of, granted I was going down a very large mountain in the Rockies. The only thing I was scared of was the tires flying apart. We were actually watching the speed rate on a GPS as well and it confirmed the same as the speedo.
Old 07-02-2007, 04:18 AM
boohoops's Avatar
boohoops
boohoops is offline
haha i like ur point about stayin alive! thats always a good thing...unfortunatley i lost to the cobra and z28 i was up against but it was all good..im in a truckso its not that big a loss to me
Old 07-02-2007, 12:01 PM
rtkota5point9's Avatar
rtkota5point9
rtkota5point9 is offline
There is a trick to get around the speed limiter. If you toggle the key to off and then back on really quick when you're near speed limiter, it will let you go past it. Don't try this at home!!..... Your driveway isn't long enough
Old 07-03-2007, 10:58 PM
02dakotakid's Avatar
02dakotakid
02dakotakid is offline
my first dakota was a 3.9 and it wouldnt shut off. it would just hold at about 110. the dak i have now has a 4.7 and it shuts down around 98. but honestly who needs to go that fast in a truck. i figure if i can cook the other guy off the line then im pretty much golden when it comes to racing.
Old 07-03-2007, 11:51 PM
f0x672's Avatar
f0x672
f0x672 is offline
well what if theres an emergency and you gotta go where you gotta go.. or wat if you just gotta take a leak really bad?.. in those situations, pedal to the metal cuts it
Old 07-04-2007, 12:28 AM
varsis's Avatar
varsis
varsis is offline
ORIGINAL: f0x672
And that is why we have the side of the road lol. Just in case you need to leak a bit.
Old 07-04-2007, 01:04 AM
98R/TDak's Avatar
98R/TDak
98R/TDak is offline
turn the key off and back on..while ur driving?...so if im correct..not being an *** or anything you attempt to turn off ur truck for a split second doing 115mph...um..yea..i dont think ill be the first to attempt that..ill let someone else do that haha and post ur results..
Old 07-04-2007, 01:16 AM
f0x672's Avatar
f0x672
f0x672 is offline
i want to say you will just slow down really quick in that split second stalling the engine while the truck is in gear, plus you dont fully turn off the pcm in that matter since you cannot really turn the key while the truck is still in gear (automatics), you can turn off the engine but i beleive that pcm is still getting juice... id rather spend the $350 on the superchips programmer to take off the speed limiter, versus risk screwing up the engine or transmission for that matter just for a quick thrill...
Quick Reply: i finally did it!!!
