o2 sensor bypass
Old Oct 27, 2017 | 04:03 AM
  #21
wyatt_lish's Avatar
wyatt_lish
Default I fu☹️cked up
I was in the middle of taking my cats out and just putting a straight pipe in and somehow the o2 sensor wire got caught in the sawzall and ripped them out. Now my check engine light, ABS and parking brake light is on and stuck on. What do I do?
Old Oct 27, 2017 | 05:41 AM
  #22
Skreelink's Avatar
Skreelink
If your ABS and Brake lights are now on from chopping a wire, sounds like you cut the abs sensor wires as well. It's the sensor ontop of your rear diff that reads the ring gear for ABS and speedometer. If your speedo stopped working under 35mph, you cut those wires. You will have to trace and rewire them.
Old Feb 7, 2021 | 08:09 AM
  #23
Eric Hank Jr.'s Avatar
Eric Hank Jr.
Not a big deal man, idk how long ago this was posted, hope you got it sorted out but otherwise just reconnect the wires and check all fuses in line with circuits you disrupted (might be alot by cutting just 4 wires)
Old Feb 7, 2021 | 09:53 AM
  #24
3 and a half years ago. I would like to think this has been fixed.......
Old Dec 11, 2025 | 02:13 PM
  #25
Mtelfer's Avatar
Mtelfer
Originally Posted by dwhess504
My truck seems to surge when it is driving mostly under 2k rpm and soes it at idle... My 2nd o2 sensor is throwing a code could that be the problem? Just wondering if any problems can result from the o2 sensor
mine was doing the same thing. Check for a coil or wire arcing out. I found cylinder 6 coil was junk my surge went away my economy came back it runs like brand new again
