low oil pressure and low idle when stopped
Old Nov 2, 2007 | 08:27 PM
  #21
blckspder's Avatar
blckspder
Default RE: low oil pressure and low idle when stopped
Thats what someone told me too, but I don't know why I wouldnt have noticed it before, and why there is gas smell coming from the exhaust.. Ill keep troubleshooting it.
Here is the pic of the piece that is loose and connected to a vacuum hose that I talked about in a previous post.
[IMG]local://upfiles/14909/AE4598506AC048F1A1EF27A69BB85446.jpg[/IMG]
Old Nov 2, 2007 | 08:35 PM
  #22
stantheman's Avatar
stantheman
Looks like where your pcv valve should be! Look down inside your throttle body and see if the bottom of the plenum is wet with oil. If it is then you need to have your bed pan gasket replaced. Common problem with the magnum engines.
Old Nov 2, 2007 | 08:47 PM
  #23
blckspder's Avatar
blckspder
The PCV valve is on the other side of the engine, that did look gunky, I was gonna get a new one this weekend. I just cleaned the throttle body, it was gunky too, had a thick residue, the inside of the body didn't look wet, but I will check it again. Thanks for the post.
Old Nov 2, 2007 | 10:14 PM
  #24
varsis's Avatar
varsis
Looks like a PCV valve to me... Shake it and if it moves it is one.
Old Nov 2, 2007 | 10:28 PM
  #25
blckspder's Avatar
blckspder
would a PCV valve be hooked up to a vacuum hose that goes to the cap that sits on top of the throttle body?
Old Nov 13, 2007 | 11:15 AM
  #26
DAK99OTA's Avatar
DAK99OTA
I am a newbie to this board and love all the advice and questions that people share. I have a '01 4.7 Quad Cab 2wd w/85kthat has the same issue as the original post ( low oil pressure and low idle, 500 rpm;at stop lights etc. )
I am going to give cleaning the throttle body a shot, my question is how easy is this? I am somewhat mechanically inclined (change my own oil, have installed K&N cold air intake on another vehicle, replace PCV valve, etc.) I looked at my throttle body and only see two sensors hooked up to it and the throttle linkage. I don't want to get it all disassembled and then not get it reinstalled correctly, wifey would kill me, not to mention I love my truck and don't want to screw it up in any way.
If somebody could let me know how easy or difficult cleaning the TB is I would appreciate it, the throttle linkage worries me.
Last thing, I love my truck for so many reasons, but the best has to be on the inside of the door "Built with pride by the people of Dodge - Dodge City - Warren, MI ",I am one of those old school people who actually try and buy things made in the USA.
Thanks in advance for your help.
