rear brake swap
Old Dec 18, 2007 | 07:56 PM
skeeter0288's Avatar
skeeter0288
Default rear brake swap
has anyone swapped the rear drum brakes over to disc?
Old Dec 19, 2007 | 12:16 AM
5 speed's Avatar
5 speed
Default RE: rear brake swap
great question, ive been thinking about doing this. either off a durango or an R/T if nothing else just for the look with my new rims. i havnt looked into it but i would think all youd need are the caliper brackets. all the other parts could be had new from a parts store
Old Dec 19, 2007 | 12:25 AM
00DakR/T's Avatar
00DakR/T
I didn't think any of this bodystyle came with rear disc......
It would be a sweet swap tho. Too bad you can't swap the rears out of the newer ones....
Old Dec 19, 2007 | 01:02 AM
300exoh's Avatar
300exoh
If you swap out the drums for durango disks you might need to change master cylinder/brake booster to meet the higher pressure needs of the disks
Old Dec 20, 2007 | 05:37 AM
98whitekota's Avatar
98whitekota
actually its been done by more than a few people. but what it is is a viper conversion kit. It changes the front and rear, it gives new and bigger rotors and calipers. I have herd that the kit isnt percise, so get ready to do some fabing yourself. You can run stock rims though (15") the rotors are two big, i think the 17" R/T rims will work. The kit is a few G's
Old Dec 20, 2007 | 10:45 AM
jnwolf2000's Avatar
jnwolf2000
My 03 quad cab slt has disc all the way around.
I've never looked real close but just guessing they are OEM.
Truck stops real well.
James
Old Dec 20, 2007 | 12:04 PM
5 speed's Avatar
5 speed
yeah ive seen durangos, some r/t's and quad cabs with rear disks
Old Dec 21, 2007 | 12:05 AM
magnethead's Avatar
magnethead
makes me wonder what mine has..never bothered to look.
Old Dec 21, 2007 | 02:42 AM
rusty dakota 04's Avatar
rusty dakota 04
i have an 04 quad cab and mine are disks all the way around
Old Dec 21, 2007 | 05:20 PM
skeeter0288
strange.my 04 regular cab 2wd has front disc/rear drum.can't understand why some would have rear disc while others would not.
