View Poll Results: A poll
2.5"
55.56%
2.25"
22.22%
2"
11.11%
1.5"
11.11%
Other - please specify
0
0%
Voters: 9. You may not vote on this poll
Dual exhaust exit Pipe Diameter
Old Mar 11, 2008 | 01:18 PM
4x4kota's Avatar
4x4kota
Default Dual exhaust exit Pipe Diameter
Ok so I did do a search and everyones opinion about exhaust manufacturer seems to be different. Thats fine, my question is what diameter pipe did you use/wish you used after the muffler. I plan on putting on a 1 in 2 outexhaust from the cat back. I've read that toolarge of a diameteryou lose your low end. And please don't let this turn into a backpressure/velocity debate.
Old Mar 11, 2008 | 02:20 PM
ricbrk's Avatar
ricbrk
Default RE: Dual exhaust exit Pipe Diameter
I went with 2.25 out from behind the muffler. Everyone was saying about low end loss if you go to big, but I notice none. I went with a Flowmaster Delta flow 40 and like the sound. "That is another controversy". I don't know if that muffler will sound good with your 3.9 though. Some like it, some don't.
Old Mar 11, 2008 | 02:28 PM
TheePlaymaker's Avatar
TheePlaymaker
on a V8 i'd say 2.25 if your going dual exits but with the V6 i'd say 2
Old Mar 11, 2008 | 03:16 PM
varsis's Avatar
varsis
The standard pipe is 2.5. So I voted the same , but 2" WILL PROBABLY keep the low end...
Old Mar 11, 2008 | 05:13 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
for the v6 i would go with 2" ID piping to fool many ppl try to keep the truck at a low rpm to makeit seem like its got a v8 my cousins 4.3 v6 sounds like a stock 350 at low idle and up to 1700rpm i havent heard it on a 3.9 though and teh tips also have a roll too big and youll ruin the sound and too little, theres no point, i have a 3.5 rolled edge on mine that are 18" long but it also has a v8 if i were you i would put 12"x 3" diamiter tip with 2" piping from the muffler back mandral bent tubing would be best also
Old Mar 11, 2008 | 07:57 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
If you guys were going to straight pipe your truck what diameter pipe would you use? would you stick with the stock size, or go bigger or smaller. I am looking to do this in the spring so i was wondering what would work best and not take anything away.
Old Mar 11, 2008 | 08:02 PM
jonnymagnum's Avatar
jonnymagnum
I have 2.5
Old Mar 11, 2008 | 10:44 PM
big.bryant's Avatar
big.bryant
yeah i have a 2.25 inch tube into a 3.5 inch slash-cut tip. it works fine, provides me enough back pressure and makes it sound good when you are going but still live-able at idle and on the highway. it can get raunchy but is still a pleasure to have
Old Mar 12, 2008 | 10:42 AM
4x4kota's Avatar
4x4kota
ORIGINAL: LoudPedal45
It seems like most people are saying 2.5", but they seem to have a V8. For the 6 it seems to me 2" or 2 1/4". I plan on goin to the exhaust shop this weekend and talk to the installer. It's a friend of a friend, and this guy is good. He usually does custom exhausts on muscle cars, but will work on anything he can get his hands on. I'll keep you posted...
