Well did some more work on it. Fixed the pinion angle as it needs to be parallel to the transmission. which is about 2 degree down, and the pinion is 2 up.
Also found the paper gasket doesn't work. So im going to have drain it all out and redo the fluids... so more $$$. Going to just use some RVT as that stuff seals anything.
aint that the truth. i lost the little rubber nose piece for my safety glasses i use when grinding metal so i made a new nose bridge from RTV. kinda ghetto, but what ever.
rtv is ok to use as a gasket on diff covers ya silly s.o.b.
That's what they used from the factory on my '05. Loctite Instant Gasket will work too, used that when I did my diff as I managed to lose the RTV I bought during the change somehow
ya kno varsis.... im not sure my bed would fit under your truck just yet.... im gonna need to do a bit of a BD...you're gonna have to lift it some more too
