Removing stock airbox, PLEASE HELP!!
Old Oct 28, 2008 | 12:58 PM
kleraudio's Avatar
kleraudio
Default Removing stock airbox, PLEASE HELP!!
Hey guys, so I took out the air box and the hose but now I'm stuck on that thing that connects to the throttle body.
I unclamped the hose leading to the throttle body, but I cant find the bolts to take off that thing that says 3.7L V6??
Any and all help is appreciated. I know bolt send me a pic of where the bolts are on the v8's but mines different.
Thanks in advance guys!
Jim
Old Oct 28, 2008 | 01:21 PM
kleraudio's Avatar
kleraudio
looks like it may need a torx screwdriver? Is that possible? I was told by numerous people that it was just a few "bolts"??
Thanks
Jim
Old Oct 28, 2008 | 02:45 PM
TheePlaymaker's Avatar
TheePlaymaker
maybe some pics? i have no clue how a 3.7 is laided out under the hood never looked at one i'm guessing its like the 4.7 but not sure. are you talking about the resonator box thing right off of the throttle body? i think mine was just 2 or 3 bolts when i took it off.
Old Oct 28, 2008 | 03:28 PM
kleraudio's Avatar
kleraudio
Well it was definitely a couple torx screws. I went to the store and got some torx screwdrivers and it was off in about 2 minutes. Sometimes I wish I had all the right tools I would need, it would have saved some 2 hours!
Anyways, its on, it doesnt exactly fit that great, the filter touches an AC line but its ok i guess. It sounds pretty good.
Heres a blurry pic, I will take some better ones when I get home.
Thanks for all your help guys! It was a lot easier than I thought it would be.
Old Oct 28, 2008 | 05:11 PM
f0x672's Avatar
f0x672
looks good dude, good job. how is the intake tube supported besides being mounted ion the throttle body?
Old Oct 28, 2008 | 07:04 PM
kleraudio's Avatar
kleraudio
Hey Fox
I really wish I could have a better answer, but I ghetto rigged this this bracket, you can see it, just to the right of the first red gasket.
Any other suggestions of how to support it would be great man! Its only got the throttle body and that one ghetto bracket, thats not even on that great, to support it.
I guess I should expect that from a 49 dollar intake!
Thanks
Jim
Old Oct 28, 2008 | 08:04 PM
kleraudio's Avatar
kleraudio
One more thing, should the CAI sound any different at idle than the old stock box? If so, I'm not noticing much sound difference. Its when I get up to about 4000 RPM when I notice the difference.
Is this normal, or should there be a noticeable sound difference even at idle?
Thanks
Jim
Old Oct 29, 2008 | 08:54 AM
rezonator's Avatar
rezonator
you wont notice any change at idle only at higher rpm tried running mine without any breather on wasnt any different at idle but a 3500 rpm with open throttle the thing was insanely loud!!!!
Old Oct 29, 2008 | 09:54 AM
fireman2828's Avatar
fireman2828
Isn't the filter supposed to go into the air box to keep hot air from engine from being sucked back into engine? Thats what supports mine. And to get more air just make the intake hole on air box a little bigger.
