Dodge Dakota lifts?
Old Nov 9, 2009 | 03:45 PM
greenreaper717's Avatar
greenreaper717
Default Dodge Dakota lifts?
I have a 2000 dodge dakota 3.9L v6...Throttle body spacer, cold air intake and flowmasters dual exhaust. It straight hauls *** and can out run most v6 trucks and almost all v8s. but i want to be able to put a suspension lift on it and throw on some larger tires for off roading. I can't seem to find one for my truck though, does anyone know where i can find one online?
Old Nov 9, 2009 | 04:45 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You may want to check the FAQ in the 2nd Generation Dakota sub-forum. I will move this there.
Old Nov 9, 2009 | 06:20 PM
rtdakota2001's Avatar
rtdakota2001
sell that throttle body spacer that is doing nothing on your fuel injected engine and use that money to save up for a body lift or if you are a big spender go for the suspension lift. i hear it's mad expensive but i dont know for sure my trucks suspension is going lower not higher. haha. oh and btw, find me and my R/T, i'll give that six of yours a run for its money
Old Nov 9, 2009 | 08:39 PM
dodgeramguy85's Avatar
dodgeramguy85
Yes as been been talked a lot about the TB does nothing on FI. As far I know there is either 1 or 2 companys that make a lift for our trucks cant think of the names off the top of my head but they run about 1,500+. Also kinda doubt the slow 3.9 with just what you have would beat a v8 unless you have more on it then what you said. My buddy had a 3.9 with a CAI, exhaust and 5 speed exact same as my truck only mine had the 5.2 and was auto which sucked then and still does today. Smoked him every time and I only have a magnaflow exhaust with the stock cat nothing else done to my truck.
Old Nov 9, 2009 | 11:49 PM
Independentfool's Avatar
Independentfool
www.4wheelparts.com
Old Nov 10, 2009 | 09:38 AM
bpark8824's Avatar
bpark8824
3.9 and hauls *** should never be used in the same sentance. I was really hoping he was joking when he made that statment... You have obviously never driven a fast vehicle before.
As far as lifts go. You can do the cheap body lift. Crank the TBs and blocks in the back. Or you can go all out and buy a suspension lift. Which are obviously the best but cost an arm and a leg. Tuff Country makes a 5.5" lift but its going to run you $1500.
Old Nov 10, 2009 | 06:24 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Here is a Copy and paste from the FAQ in this section.
Lift kits
4wd
Body kit 2in.
http://www.summitracing.com/parts/PRA-PA-682/
3in
http://www.summitracing.com/parts/PRA-PA-693/
Full suspension kit 4in. ($1,700)
5.5 in. Front, 5.0 in. Rear
http://www.summitracing.com/parts/TFY-35940/
2in http://4wheelonline.com/Products.asp...roductID=72043
Lift/ Indexed Torsion bar keys/ Anchors 2-3 inch. Lots listed on http://www.ebay.com/
http://www.totalperformanceonline.co...log/X381321/30
Or you can just crank your torsion bars and add rear blocks for 1 inch or so.
You can tack weld some 1/4 inch steal strips to your keys. Here is a post on it. 1st-gen-Dakota/175855-cheep-lift-post1417241.html#post1417241
You can get blocks just about any parts stores. Sizes are available from 1 inch - 6 inches.
You can get Shorter rear spring shackles.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen-...ut-blocks.html
https://dodgeforum.com/forum/1st-gen-...le-hanger.html
If you got a V6 you can get V8 torsion bars to give you an extra inch or so.
Add a leaf too.
http://www.jcwhitney.com/ADD-A-LEAF_...;0;2005974;0;0
http://www.summitracing.com/parts/TRA-R1536/
You can get air shocks too. These are not air bags. So you don't need an on-board compressor.
https://www.shockshopusa.com/air-shocks.html
Air bags
http://www.summitracing.com/parts/AIR-59508/
http://www.streetbeatcustoms.com/Air...RF5009/554466/
http://www.avsontheweb.com/home.php?cat=440
www.google.com and do a search.
Universal Air bags. https://airbagit.com/index.php?osCsi...beeed6ca3c2580
You can get coil over rear shocks. It may add 1-2in of height. http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=MON&MfrPartNumber=58630
Old Nov 10, 2009 | 06:38 PM
dodgeramguy85
Yes very true I drove my uncles 08 jeep grand cherokee srt8 tonight now thats a vehicle that hauls some major ***. Anyone want to loan me about 45,000??
Old Nov 12, 2009 | 03:45 AM
dakota02guy's Avatar
dakota02guy
im having trouble finding a lift for a NON 4x4 dakota, 2002... any ideas
Old Nov 12, 2009 | 01:41 PM
Crazy4x4RT's Avatar
Crazy4x4RT
A non 4x4 is called a 2wd! You may want to check the FAQ in this section.
Here is a copy and paste.
2wd
Full suspension lift 3in.
http://www.fabtechmotorsports.com/ap...tadurango.html
You can use the 2in body kit. It says only for 4wd, but slight modification may be necessary.
Body kit 2in.
3in
For the front you can get coil spacers. Use one on top and one on the bottom for 2in lift. http://store.summitracing.com/partde...p;autoview=sku
http://store.fatbobsgarage.com/share...t=products.asp
If you got a V6 you can get V8 coils to give you an inch or so or custom coil springs. Ebay.com may have some.
For the rear, you can use shorter spring shackles.
Or flip your shackle hangers. Check out https://dodgeforum.com/forum/1st-gen-...ut-blocks.html https://dodgeforum.com/forum/1st-gen-...le-hanger.html
Add a leaf too.
You can also do a spring over axle swap. But this will add around 5 inches of lift just for the back. After a SOA swap, you can use lift blocks. Sizes are available from 1 inch - 6 inches.
https://www.shockshopusa.com/thankyou.html
Air bags
