so got bored, again lol
Old Mar 16, 2010 | 12:19 PM
  #21
TheePlaymaker's Avatar
TheePlaymaker
you'll notice it more if you do lots of city driving like someone said when your cruising on the highway the clutch fan never comes on so its only there for low/city driving
Old Mar 16, 2010 | 12:53 PM
  #22
United's Avatar
United
Pretty neat little mod there, I like that.
So how do I know if I have an e-fan? I'd like to do this, but I don't want to do anything that could cause damage to my truck.
99 Sport, 3.9 w/ 180* therm (if this tells anyone anything)
Old Mar 16, 2010 | 01:37 PM
  #23
thunder98110's Avatar
thunder98110
just look. i think 2000+ years have them, not sure about the 99
Old Mar 16, 2010 | 01:58 PM
  #24
United's Avatar
United
Ok, I clearly do not have one. Would I run into any overheating issues if I remove the clutch fan? I know its a very broad question, but I want to make sure I don't run in to any major issues.
Old Mar 16, 2010 | 02:21 PM
  #25
Josh Abels's Avatar
Josh Abels
yes u would prolly overheat
and its the 4.7Ls that come with the efan stock
  #26
thunder98110
i personally wouldn't do it, but i think its safe if you do highway driving, if its city and hot outside then prob not.
Old Mar 16, 2010 | 02:37 PM
  #27
User's Avatar
User
Originally Posted by MadisonDakota
You do have to consider that the Toyota engine has Variable Valve timing, 4 valves a cylinder, and DOHCs, and a 6 speed transmission. Of course it will be better than a pushrod V8. When you take stuff that was meant to make little engines fast and put it on a big engine....you get a fast *** engine.
ok. My point was its faster then a titan and puts up a better challenge then the titan. Im not new to VVT and DOHCs. Point is if you think a Titan is fast go race or drive a Tundra then come talk.
Originally Posted by Josh Abels
yea thats the plan in the long run but i dont really wanna drain the cooling system to switch out the tstat
You dont have to drain the cooling system..... Take off the top radiator hose you might loose maybe 1qt of coolant IF its filled all the way up (which im going to guess its not. Take the thermostat housing off and put the new one in i use RTV to seal it, and put it back on... you dont have to drain the system its a 10min job.
Do it fast...haha The tstat doesn't really help, think about it. When you're moving, there's enough air moving to keep it from reaching 212. When you're stopped, the fan has to kick on. There is a little bit of gray area that the fan would have to work for that it wouldn't have to work for if you had the 180 tstat, but IMO it's not worth it.
Yes it is worth it, The E fan is good but not good enough for stop and go driving or high heat idles, the 180 thermo will help out big time with this. I highly suggest you run a 180 if you remove the clutch fan. Otherwise you might find yourself purchasing some head gaskets.
You need some type of air moving in the front at idle.
4.7s are NOT the only ones that came with stock e-fans. Both my 2000 and 2001 have stock e fans on them and they are the 5.9.
Old Mar 16, 2010 | 02:44 PM
  #28
Josh Abels's Avatar
Josh Abels
ok thanks for clearing that up on the efan being stock ive never had my hands on any other than the 4.7 and the 5.2
for the tstat the haynes manual says to drain the system and the tstat aint on the top hose on the 4.7 its on the bottom hose
Old Mar 16, 2010 | 03:08 PM
  #29
User's Avatar
User
My bad, didnt even notice you had the 4.7. Even though it says it like 15 times in your sig.
Old Mar 16, 2010 | 03:43 PM
  #30
Josh Abels's Avatar
Josh Abels
No prob LOL I wish I had the 5.9 I would supercharge the hell outa that thing
