suspension lift
Old Jan 9, 2011 | 06:07 PM
Dodge Trooper's Avatar
Dodge Trooper
Default suspension lift
i have searched EVERYWHERE and i cant find a decent suspension lift for my 2002 club cab dodge daktota. please can ANYONE tell me where to get a suspension lift for my truck and what size it is.
does anyone have a link to a site that sells lifts for my truck?
Old Jan 9, 2011 | 06:12 PM
TheePlaymaker's Avatar
TheePlaymaker
there is basically one suspension lift I think its 5.5 inches, for these trucks. it's made by tuff country. you'd pretty much be better off doing a solid axle swap or getting a jeep imo.
Old Jan 9, 2011 | 06:15 PM
Dodge Trooper
how do i do a solid axel swap and what does it do?
Old Jan 9, 2011 | 06:35 PM
Dodge Trooper
i looked up the tuff country lift but its for 97-99 dakotas, will that work with my truck? btw im 4x4 so no coils
Old Jan 9, 2011 | 07:23 PM
cowboy63645's Avatar
cowboy63645
Simple answer, no, it wont work on your truck. As far as a SAS, type it in to google and you will find ALOT of threads of what goes into it. If your truck is mainly used on the street, put on a 3" body lift, larger tires and call it a day. If your truck will be seeing alot of offroad/hard use, then you might want to look into a SAS. An SAS, in short, you rip all of the IFS from your truck, and put a solid front axle under it. You will gain approx. 6-9" with a set of mild lift springs (4"-6")
Old Jan 9, 2011 | 07:48 PM
Pwall's Avatar
Pwall
you can also do a 2" torsion bar and shackle lift
IFS is independent front suspension
Old Jan 9, 2011 | 09:07 PM
Blaze10's Avatar
Blaze10
at most is a 3 inch body and crank the t bars up and throw 2" blocks under the rear axle to give you the 5 inch total lift. that's all you will be able to get out of it
edit: That is without doing the suspension lift, tuff country lifts are not one of my favorites.
Old Jan 9, 2011 | 10:14 PM
dodgeramguy85's Avatar
dodgeramguy85
If im spending 2 grand there is no way im keeping a torsion bar setup. I would MUCH rather spend the extra hours doing a sas cause once its done it will be worth it
Old Jan 9, 2011 | 10:16 PM
fourpointseven's Avatar
fourpointseven
SAS FTW!!!! Too be honest, i'd rather leave my dakota STOCK then go to the Aftermarket Keys... It totally ruins the ride of the dakota, IMO is nice!! But...Sas your dak and your riding on a cloud.. very nice
Old Jan 11, 2011 | 10:40 AM
Dodge Trooper
ok, if i do the sas swap will i lose my 4x4?
can i get one from a junk yard or does it have to be only for my 2002 dodge dak?
how much will it cost to get a pro to swap it out or can i do it?
if i cant get it from the junk yard where can i get the axel and all the parts needed?
and i suppose this allows me to put 2wd coil suspension on my truck?
