help
Old Jun 15, 2011 | 06:38 PM
ezmoney's Avatar
ezmoney
Default help
HI there first off will say I am new to the forum. I have some issues with my 2001 dodge durango 4X4 with 4.7 it started about a year ago when the timing chain broke on driver side I tore it down to find that I got 4 bent valves took to shop and they had heads done and all new timing components got it back from shop ran like crap would not idle they said it needed idle air motor and tps I changed them still the same took it back to the shop and they said I needed ecm so I bought an ecm had it flashed and put it in still the same also changed cam and crank sensors could anyone tell me what is wrong it will start and idle for just a min or two then die runs down highway ok
Old Jun 15, 2011 | 06:46 PM
thunder98110's Avatar
thunder98110
ouch, did they set timing correctly? sounds like timings off.
Old Jun 15, 2011 | 06:59 PM
ezmoney's Avatar
ezmoney
they said it was but I don't know for sure how to tell?? You can't use a timing light sad thing is that it has been a year since it broke down and still can't drive it only got to drive it for 5 months before it broke
Old Jun 15, 2011 | 07:12 PM
thunder98110
you can take both valve covers off and position 1 cam sprocket at TDC and the other should be the same. if its not then timing is off.
Old Jun 15, 2011 | 07:15 PM
ezmoney's Avatar
ezmoney
ok will try tomorrow after work
Old Jun 18, 2011 | 12:07 PM
ezmoney's Avatar
ezmoney
Well I checked it and it is out of time but to re time it don't you have to have special tools and well I think I need to get a rebuild kit oil pressure sucks and it smokes some times what would you recommend rebuilding the one I have or going with a remand unit
Old Jun 18, 2011 | 12:28 PM
spyknee's Avatar
spyknee
Maybe the distributor is not turned to proper spot???????????????????
Too simple..............................
One things for sure, you need to run up your mechanics **** if he put it back togather improperly. Get your labor dollars back, at least. Shops charge 75$/hr +/-.
Old Jun 18, 2011 | 02:53 PM
ezmoney's Avatar
ezmoney
I would love to get money back from them but better to leave it alone don't have the money to sue but as for the truck it does not have a distributor coil packs the timing is adjusted by ecm if the cams are in time
Old Jun 18, 2011 | 04:25 PM
ryan_brown33's Avatar
ryan_brown33
maybe the 4.7's dont have distributors hmmmm, so i wouldnt be a smart *** by saying its "too simple" unless you have your facts straight first
Old Jun 19, 2011 | 10:24 AM
ezmoney's Avatar
ezmoney
so was doing some thinking and was wondering what year model 4.7 would work for 01 durango has 16 tooth tone wheel
