Shift kit anyone ?????
Old Jun 26, 2011 | 09:40 PM
yfz450man's Avatar
yfz450man
Default Shift kit anyone ?????
I have an 03 QC dak 4.7 with a 45 trans has anyone put a shift kit in and if so were you happy, I hate the way these slide into gear and would like to firm up the shifts thanks
Old Jun 26, 2011 | 10:07 PM
thunder98110's Avatar
thunder98110
search for sonnax and tmr mod.
Old Jun 26, 2011 | 11:59 PM
sl2racer's Avatar
sl2racer
i thought the tmr mod doesn't work on the 03 and 04
Old Jun 27, 2011 | 09:00 AM
thunder98110
only if you have a 3plug pcm.
Old Jun 27, 2011 | 12:13 PM
yfz450man's Avatar
yfz450man
Thanks for the replys, so here is my next question, can I assume that this truck 03 4.7 dakota does not have a separate TCM ?, and if my assumtion is correct then which out of the four plugs is this wire in, i did a search and found info on the procedure on how to do it to a Ram but mine doesn't appear to be the same
Thanks guys O one more thing can I do both mods the sonnax and TMR
Old Jun 27, 2011 | 12:24 PM
thunder98110
you can only do the tmr if you have a 3plug pcm. sonnax you can do is you have a 45rfe trans.
Old Jun 27, 2011 | 01:36 PM
yfz450man's Avatar
yfz450man
I got ya, thanks what are your thoughts on a complete shift kit, like transgo ?
Old Jun 27, 2011 | 02:05 PM
thunder98110
not worth it. might as well swap valve bodys if you are going to go that route. look up, sharadon stage 3 VB.
I'm really pleased with what the sonnax did for me.
