Need advice on muliple misfire codes
Old Jul 17, 2011 | 01:16 AM
mcvoss's Avatar
mcvoss
Default Need advice on muliple misfire codes
My daughter has a 2001 3.9 Dakota.
I have done the following 2 months ago:
New Plugs
New Plug Wires
New Dist Cap and rotor
New Cam shaft pos. sensor
New Crankshaft pos. sensor
The truck just started running rough again and I am getting the following fault codes. 300, 301, 303 and 305. They are obviously cylinder misfires. Any suggestions what else could be causing this?
Thank you folks in advance
Old Jul 19, 2011 | 12:40 AM
99-318's Avatar
99-318
Could the coil be not putting out enough? Maybe give that a shot there cheap
Old Jul 19, 2011 | 12:28 PM
crateampsrock's Avatar
crateampsrock
Oddly enough cylinders 1 3 and 5 are all on the same side. I would check the order which you have the wires hooked up.
Old Jul 19, 2011 | 12:31 PM
crateampsrock
sorry dbl posted...
Old Jul 20, 2011 | 12:02 AM
mcvoss's Avatar
mcvoss
Thanks guys. Bought a coil tonight and will install tomorrow and make sure I didn't mess up the order of the wires. I'll post back. Thank you both for the suggestions.
Old Oct 17, 2018 | 03:46 PM
Robert Heath's Avatar
Robert Heath
Default Same codes.
Hello all . I have a 08 ram 5.7 . I get the same misfire code's only after hitting a rough bumps on right side. Tried to see if it would happen on left side . Tried to hit the same patch with left side no problems. Any advice on why it is right side only ?
Old Oct 17, 2018 | 04:13 PM
7 Year old thread, and you are in the wrong section. You want to be in the 3rd gen ram tech section.
Old Oct 17, 2018 | 06:40 PM
Robert Heath
Thank you I will go to gen 3
