Brake Trouble
Old Jul 29, 2011 | 09:03 AM
01KotaQuad's Avatar
01KotaQuad
Default Brake Trouble
So last night my pedal went soft, now this morning my abs and brake light r on, pedal is REALLY soft, have fluid, no leaks. Any ideas? When I push it to the floor o can hear it squeak too...and I'm lost...
Old Jul 29, 2011 | 10:04 AM
00DakDan's Avatar
00DakDan
Section Moderator
It could be a failure of the master cylinder. Fluid is basically leaking internally so you're not developing pressure.
Old Jul 29, 2011 | 01:08 PM
01KotaQuad's Avatar
01KotaQuad
Would that be on the brake booster?
Old Jul 29, 2011 | 01:11 PM
01KotaQuad's Avatar
01KotaQuad
Nevermind...brain fart I was thinking something else, master is where u put the fluid
Old Jul 29, 2011 | 01:16 PM
01KotaQuad's Avatar
01KotaQuad
Is there any way to troubleshoot?
Old Jul 29, 2011 | 02:32 PM
00DakDan's Avatar
00DakDan
Section Moderator
Try this, step hard on the brake. Does it grab then start bleeding down?
There aren't any good clues, it's mostly exclude the rest of the stuff.
If you don't see any visible leaks then the only likely place is at the master cylinder. Since it is not low on fluid it isn't likely leaking out the back of the master cylinder either so it probably is internal.
Old Jul 29, 2011 | 08:59 PM
01KotaQuad's Avatar
01KotaQuad
Yeah sometimes at first it's stiff then goes soft, and it will also just go straight to the floor but yeah u can feel the play in it...
Old Jul 29, 2011 | 10:10 PM
00DakDan's Avatar
00DakDan
Section Moderator
It looks like you'll need to replace the master cylinder then.
Old Jul 30, 2011 | 08:27 AM
01KotaQuad's Avatar
01KotaQuad
Well find out this weekend...bleed them too huh?
Old Jul 30, 2011 | 10:25 AM
00DakDan's Avatar
00DakDan
Section Moderator
Yup, you'll definitely need to bleed the entire system.
Make sure you bench bleed the master cylinder before you install it or it'll take you forever to get the air out of the lines.
