Power Window Problem (or worse)
A little late on the reply but this recent post reminded me to post an update. I purchased a new driver side window control panel on an online auction site ($50 I think) and it worked like charm. Everything works now!
he replied that replacing the switch unit as a whole solved the issue. In the 03 Dakota Quad Cab I just picked up only the drivers controls work on the windows. Im guessing the childs lock out is to blame but ive not opened it up to clean the contacts or such.
Just bought this dak and the driver window is stuck down and the rest are stuck up. Nothing works. Not even the mirrors will move. Went the the junkyard got a new master switch for $5 put it in..... Still no window action but the mirrors function now. Any tips?
There isn't one.
There are individual fuses for the systems that constantly draw power:
Radio
Amplifier
CTM
PCM
Cluster
Combination Flasher
Radio
Amplifier
CTM
PCM
Cluster
Combination Flasher
Mine was the control board in drivers door .<br /><img src="https://cimg9.ibsrv.net/gimg/dodgeforum.com-vbulletin/2000x1124/20200430_134832_57273185dd553f957cc30dd310892f90b7 296c66.jpg"></img><br />The button in these in the child lock can mess things up .<br />This is the circuit board but you can easily change the plug in control.<br />Also be sure the connector is secure ,these have been known to have issues at the connector.<br /><img src="https://cimg2.ibsrv.net/gimg/dodgeforum.com-vbulletin/2000x1504/20200304_124624_fba6ced603b5d264e3b74c5d74ca663852 b217b0.jpg"></img><br /><br />
