Crank Position Sensor
Old 10-18-2011, 09:13 PM
bill9000's Avatar
bill9000
bill9000 is offline
Default Crank Position Sensor
Howdy! I am trying to chase down a problem with my 97 Dakota 318 not starting, (it quit in the middle of driving and wont start since.) - has no spark, and no fuel pump, and the gauge shows E...
I am in the middle of trying to source the problem...
I am trying to find things that would cause it to have no spark and no fuel, I have already replaced the PCM, amd I've tested all the fuses and relays, especially the ASD relay, which I even swapped with others, and still doesnt work.
What I am wondering is: Can the Crank Position Sensor cause it to maybe trip the ASD, which is in turn killing the spark and fuel? (I'm guessing the fuel gauge is tied to the fuel pump circuit which is why it's not working)???
any help would be greatly appreciated, I am in bad trouble without this truck running....
Have a great day!
Old 10-24-2011, 01:06 PM
bill9000's Avatar
bill9000
bill9000 is offline
UPDATE: - Troubleshooting and fix... done. - Problem WAS the Crankshaft Position Sensor, the wire going to it was pinched between the engine/transmission and shorted it out. and the symptom was no fuel, no spark & no gas gauge working. Put in new sensor, truck fired right up. Hope this helps someone else out sometime.
Old 10-24-2011, 03:10 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Glad you got it Bill and thanks for sharing the fix.
Quick Reply: Crank Position Sensor
