Heater Fan
Old Dec 2, 2011 | 06:45 AM
Robertwav1's Avatar
Robertwav1
Default Heater Fan
May be time for a fan motor replacement for HVAC. Has anyone done this on a 98 dakota?
I searched the threads here but came up with the ram replacement. Involves removing the dash. Just wondering if the dakota is the same. Thanks for any tips!
Old Dec 2, 2011 | 08:02 AM
Ts610's Avatar
Ts610
What is it doing? I am dealing with this right now and found my issue.
Old Dec 2, 2011 | 10:19 AM
Robertwav1's Avatar
Robertwav1
Okay, what it seems like it's making a little noise now and then but it clears up. It did this once before and I attributed it to leaves or something like that where the fan resides however, I had it a little this morning and again it cleared up. Sounds a little like a dry bearing. ??? Just don't want to lose it as the cold is comming....Thanks!
Old Dec 3, 2011 | 09:13 AM
Ts610's Avatar
Ts610
I haven't changed to blower fan yet but am getting ready to change the resistor as mine will not work on the high setting. Your fix appears to be the same as mine almost though. Under the glove box.
Old Dec 3, 2011 | 10:23 AM
00DakDan's Avatar
00DakDan
Section Moderator
You have to pull the dash to change the fan. As long as you're in there you may as well change the heater core.
Resistor location varies depending on the year. Up to 2000 its under the cowl.
Old Dec 5, 2011 | 07:27 AM
Robertwav1's Avatar
Robertwav1
Red face
Kind of figured that. I would definitely replace the heater core also if I have to take it apart. So far it's pretty quiet again so maybe I'll get by for a while. Maybe the heater core will go first and then I can replace the fan...
Old Dec 8, 2011 | 10:25 AM
darrelldubree's Avatar
darrelldubree
If your core is not leaking, I would leave it alone.
Good day
Old Dec 8, 2011 | 02:54 PM
98DAKAZ's Avatar
98DAKAZ
Default cheap so why not
They are cheap so why not replace the heater core you are in there, you may as well do it you don’t want to put it all back together then next year your heater core starts leaking on you.
At least give it a good looking over same with the evap core and look at the foam seals and replace if needed that foam dies after about 10 years pulling the box out disturbs those seals just buy some quality foam at home depot that’s the same size to replace them with.
