P/S whine will not go away!!!!!
All I can find by me is the Lucas Power Steering Stop Leak. It says it renews worn rack & pinions and controls squeals and hard spots. Seems like it's thick as molasses.
I did also find Lucas Power Steering Fluid that has conditioner in it, but it's a lot thinner, like any P/S fluid or ATF is, and it actually says for existing whine or squeals use the Power Steering Stop Leak.
Is putting this Stop Leak in a system that doesn't leak gonna hurt anything? How long can it stay in there?
Thanks.
Thanks.
Well I dumped a full 12oz bottle of the Luca Stop Leak in it yesterday. Ran the engine for a bit beforehand and turned the wheels back and forth a bunch of times to get the fluid heated a bit, and had the Lucas in the furnace room so it was good and warm so it would flow out of the bottle good, since it's as thick as tar and it was 15 degrees out yesterday.
Took as much fluid as I could out of the reservoir and dumped all of Lucas in, ran it at idle for a bit and then turned the wheels back and forth a bunch of times to get it circulated, went and drove around the block a few times and came back........and no difference. Whine is still exactly the same both on acceleration and turning, turning is obviously way worse.
I'm gonna let it sit in there and drive it a bit more, just to see if it needs some time to condition any seals, wasn't really expecting instant results as the bottle says, so I'll wait a couple of days and post back, but I'm not too optimistic.
Alright well this stuff did nothing but make it worse. When I start it up in the morning after it's been sitting all night, the pump squeals for a second as loud as can be since the stuff is so thick, and then even if I let it run for 10 minutes before going anywhere the steering is so stiff it's almost like not having any power steering.
I could be crazy but I think the pump is actually louder all the time with this stuff in it. If it sits for like 3-4 hrs after I get to work and I come back out it doesn't squeal at startup but the steering is stiff as can be again. It sings pretty damn bad when maneuvering into and out of a parking spot too.
I want this stuff out, gonna flush it tonight, I can't deal with another squealing morning startup. Hopefully I haven't ruined my new pump with this stuff.
Is there any advantage to keeping this stuff in a bit longer, or is it not worth having my pump squeal for a second at startup and possibly ruining the pump?
Never use stop leak unless you have no choice it coats the inside of your system with a rubbery substance that can gum up everything that’s how it stops leaks.
I know I used it one time my power steering fluid presser sensor was leaking so I used it then got it fixed a few months later.
Well this year I decided to change out my fluid and do a flush of the system I have the 2.5L engine that engine has an external tank for the fluid upon inspection of the tank I noticed the tank had a thick film of rubber like crap inside it I will tell you it took a ton of solvent to clean it all out if it’s on the tank it’s on everything in the system.
I flushed the system out two times getting that crap out.
So beware of stop leak crap.
Yeah it's a re-manned pump, a Cardone. It sounded exactly the same as the factory one that I took off, before I put the Lucas in it. It is only a very quick squeal/chirp when it's dead cold in the morning, then goes right away, but the steering is stiff as can be until you start to move and bring the RPM up.
I am gonna flush the Lucas out tomorrow, too damn cold tonight. Is this a known thing with Dodge p/s systems, do they tend to make noise like this?? Starting to think I am chasing a problem that can't be solved.
