Is my power steering pressure switch is causing my idling issue?
Well I suggest
Well I suggest it’s the non-fouler trick when you start screwing with these systems you are bound to have some problems.
The system was designed to work with all sensors and all components like a CAT or O2 present sounds like the computer is not happy with the info its getting from the non-fouler trick on the O2 sensor.
I think screwing with these systems just to get a few more HP is just going to cause havoc with the system eventually.
lets be clear
let’s be clear to clean the TB you must remove it from the engine then you must remove all sensors IAC, TPS, MAP then spray the crap out of it with carb spray and use Q-Tips to get way back inside the TB IAC chamber.
Best is if you have a can/tank/vat to soak the TB in for half a day in carb/parts cleaner not sure you can get this anymore.
Next carefully clean the IAC by hand with some carb cleaner and a rag/towel you don’t want to spray directly into the IAC or you will trash it don’t try to clean the MAP or TPS sensors you will trash them if you do.
Inspect TB for bad wear sloppy linkages damage or loose parts fix if needed. Inspect the IAC, TPS and MAP for damage replace if needed.
Let dry then apply a small amount of lube to the linkage parts that move around when in use I used some Mobile 1 oil.
Replace all sensors re-install the TB done.
Just to be clear on how to remove and clean the TB.
But I did however clean the IAC and sprayed carb cleaner directly on it and I was kind rough on it trying to get the build up off of it. So I may have damaged it.
