Is my power steering pressure switch is causing my idling issue?
I have read from my researching and I believe my power steering pressure switch is causing my truck to die when it comes to a stop at a red light or when I'm creeping through a drive thru. How do I know if this is my idling problem because its driving my insane almost everytime I stop at a light my truck dies?
Can anyone help me?
Also this is on my 00 4.7 auto 4x4
Can anyone help me?
Well if you cleaned the TB next would be
Well if you cleaned the TB next would be a tune up plugs wires coil cap rotor all very cheap stuff if not done in a long time. Then if still having problems all the sensors is the next step O2, IAC, TPS all those then you’re CAT, muffler or fuel system fuel pump injectors.
Are you running cheap gas through it? Tried a can or two of seafoam or other fuel injector cleaner those do help.
Trending Topics
And I have ran two bottles of seaoams with fuel, and I only run good non ethanol gas.
