2000 Dakota not turning over-help
Old 03-18-2012, 07:23 PM
Johnny Coolkat's Avatar
Johnny Coolkat
Johnny Coolkat is offline
Default 2000 Dakota not turning over-help
I'm stumped on this one. I have a 2000 Dakota 4.7 that will not turn over. I had a similar problem before and that was fixed by replacing the starter. I put in a new starter, the battery and it's connections are good, the starter relay is good, fuses are good. I turn the key and I hear the fuel pump and relays engage but nothing from the starter. Any suggestions are greatly appreciated.
Old 03-18-2012, 08:53 PM
MoparMan1991's Avatar
MoparMan1991
MoparMan1991 is offline
You may have bought a bad starter. Take it back and get another.
Old 03-19-2012, 08:56 PM
Johnny Coolkat
I'm not sure if that's the case. In the past, it has been progressively worse to start the truck and replaced it. That did the trick. In this case, it was all of a sudden the truck started one minute and the next nothing.
Old 03-19-2012, 10:21 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
You hear the relay in the PDC clicking when you turn the key to start? Check fuse #9, it's a 40 amp in the PDC, it feeds the starter solenoid.
Do you hear that click? It'll be loud.
It's not unheard of to have the battery terminals fail internally. Check for power at the starter itself.
Old 03-21-2012, 09:24 PM
Johnny Coolkat
My buddy got me a wiring diagram and that's funny because it agrees with what you mentioned. It actually happens to be slot 8 and it's a 50amp. Straight jump from the positive cable starts it up. It also turned over once from neutral once. This leaves me with 2 options. The ignition switch or neutral safety switch. Thanks for the help but I'll let you know what I find out.
Old 03-22-2012, 05:39 PM
moe7404's Avatar
moe7404
moe7404 is offline
ALL WAYS test a new starter on the bench before potting it on the engine. Daaaaa
Old 03-25-2012, 05:16 PM
Johnny Coolkat
Does anyone know where the neutral safety switch is located? I got a treaded one for a 3pin connector. It matches the close up pictures that appear just on top of the pan but I'm not finding that. An overall picture would be most helpful.
Quick Reply: 2000 Dakota not turning over-help
